Dayton Audio QT385-4 15" Quatro Subwoofer 4 Ohm
Brand:|Part # 295-560
This 15" Quatro offers a large radiating area and low Fs for powerful bass. In an auto application it will play incredibly low and is great for larger vehicles. For home theater a 3 cu. ft. sealed box works great, but larger vented enclosures can also be used.
Comparable Items In Stock:
Part # 295-560
  • Santoprene® Rubber Surround
  • Heavy Gauge Stamped Steel Frame
  • Kevlar® Impregnated Coated Paper Cone
  • Large 4-layer V.C. with Kapton® Former
  • Easy-to-connect Pushbutton Terminals
  • Vented Pole Piece
  • Bumped Back Plate
The Quatro™ Series subwoofers have been designed and built based on the well-respected platform of the Dayton Series II woofers. By implementing a 4 ohm voice coil and extending the excursion capabilities, the Quatro™ woofers now become serious contenders for home theatre and automotive use. The long excursion design and high sensitivity allows you to take advantage of modest power amplifiers, while the relatively high DC resistance makes them very friendly to 4-ohm stable amps and will not cause overheating or other amplifier stability problems.
Specifications: • Power Handling: 300 watts RMS/600 watts max • VCdia: 2-1/2" • Le: 2.4 mH • Impedance: 4 ohms • Re: 3.5 ohms • Frequency range: 20-125 Hz • Magnet weight: 67 oz. • Fs: 23 Hz • SPL: 91.8 dB 2.83V/1m, 88.8 dB 1W/1m • Vas: 5.89 cu. ft. • Qms: 12.57 • Qes: 0.43 • Qts: 0.42 • Xmax: 9.84 mm • Dimensions: Overall Diameter: 15-1/8", Cutout Diameter: 13-7/8", Mounting Depth: 6-5/8".
  • BrandDayton Audio
  • Part Number295-560
  • UPC844632000140
    (13 Reviews)
  • Weight16.8 lbs.
View similar products to the Dayton Audio QT385-4 15" Quatro Subwoofer 4 Ohm
