Clearance Item
268-332_ALT_0
Dayton Audio PT4-IF 4" Speaker Cabinet Inside Port Tube Flare
Brand:| Model: PT4-IF
Dayton Audio Create-Your-Own Flared Port Tube System- A selection of flares, elbows, and straight tubes allows you to create a port that will fit in any cabinet. Constructed from very high quality ABS plastic, the aesthetics of these ports is heads-and-shoulders above similar products.
  • Create-Your-Own flared port tube system
  • Selection of flares, elbows, and straight tubes
  • Constructed of high quality ABS plastic
  • Available inside and ouside flaring to minimize port noise
268-332
Weight: 0.75 lbs.
IN STOCK
List Price$13.99
You Save43%
$7.97
Buy 4-up$7.59
Part # 268-332
Dayton Audio Create-Your-Own Flared Port Tube System- Ports are an integral part of any loudspeaker system, so why skimp where it counts? Dayton Audio has developed the first a la' Carte port tube system that allows you to buy the parts you need to get the tuning you want. A selection of flares, elbows, and straight tubes allows you to create a port that will fit in any cabinet. Constructed from very high quality ABS plastic, the aesthetics of these ports is heads-and-shoulders above similar products. 4" diameter inside flare
  • BrandDayton Audio
  • ModelPT4-IF
  • Part Number268-332
  • UPC844632054389
  • Product CategorySpeaker Port Tubes
    (1 Reviews)
  • Weight0.75 lbs.
View similar products to the Dayton Audio PT4-IF 4" Speaker Cabinet Inside Port Tube Flare
in the Speaker Port Tubes product category.
Dayton Audio PT4-IF 4" Speaker Cabinet Inside Port Tube Flare is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Solid ProductFor you designers out there I will give you the actual critical dimensions:Major outside Diameter at flare 5.725"Depth of flare 1.093"Total depth 1.683"Fits tube diameter of 4.125"Inside minor diameter of flare 3.950"The flare depth is the distance from the outer edge of the flare down to where the 4" straight pipe would end meet.When calculating your vent tube length make sure you include 1.093" for the length of the flare.The only downside is that these are a little pricey, but otherwise a good product.
Date published: 2009-03-21
Customer projects that include: Dayton Audio PT4-IF 4" Speaker Cabinet Inside Port Tube Flare
