Dayton Audio PS220-8 8" Point Source Full-Range Neo Driver
Brand:|Model: PS220-8|Part # 295-346
The Dayton Audio PS Series drivers do it all: true bass, articulate midrange, and balanced, extended highs.
List Price$166.99
Regular Price$128.00
You Save14%
Sale Price
$109.90
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 295-346
  • High sensitivity/minimal distortion—an ideal match for lower powered amplifiers
  • Parasitic HF cone and carefully engineered phase plug extend on- and off-axis response
  • Solid bass performance, thanks to usefully high excursion capability (5 mm Xmax)
  • Optimized neodymium magnet provides high motor strength
  • Low-mass copper clad aluminum voice coil
  • Copper cap and copper ring on pole piece reduce inductance and distortion
  • Kevlar reinforced paper cone is lightweight yet rigid and well controlled
The Dayton Audio PS Series drivers do it all: true bass, articulate midrange, and balanced, extended highs. An intensive program of design and testing has yielded full-range speakers that feature high sensitivity and smooth response, both on- and off-axis. Although an ideal match for lower powered Class A and Class T designs, the PS220-8 8" driver's superb resolution and natural sound quality make it a viable option for an even wider variety of applications. The PS Series' audio performance is complemented by the speaker's striking appearance—they look great in dipole and other open back designs, too!
  • Nominal Diameter8"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance8 ohms
  • Frequency Response40 to 25,000 Hz
  • Sensitivity96.5 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)46.4 Hz
  • DC Resistance (Re)6.2 ohms
  • Voice Coil Inductance (Le)0.73 mH
  • Mechanical Q (Qms)5.73
  • Electromagnetic Q (Qes)0.40
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)3.19 ft.³
  • Mechanical Compliance of Suspension (Cms)1.41 mm/N
  • BL Product (BL)6.15 Tm
  • Diaphragm Mass Inc. Airload (Mms)8.4g
  • Maximum Linear Excursion (Xmax)4.8 mm
  • Surface Area of Cone (Sd)216.4 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.72"
  • Baffle Cutout Diameter7.13"
  • Depth3.7"
  • Bolt Circle Diameter8.27"
  • # Mounting Holes6
  • Sealed Volume0.5 ft.³
  • Sealed F3108 Hz
  • Vented Volume1.15 ft.³
  • Vented F368 Hz
  • BrandDayton Audio
  • ModelPS220-8
  • Part Number295-346
  • UPC844632088803
  • Product CategoryWoofers
    (20 Reviews)
  • Weight4.8 lbs.
View similar products to the Dayton Audio PS220-8 8" Point Source Full-Range Neo Driver
