Dayton Audio PS180-8 6-1/2" Point Source Full-Range Neo Driver
Brand:|Model: PS180-8|Part # 295-344
The Dayton Audio PS Series drivers do it all: true bass, articulate midrange, and balanced, extended highs.
List Price$129.99
You Save31%
$89.85
Buy 4+$85.36
Part # 295-344
  • High sensitivity/minimal distortion—an ideal match for lower powered amplifiers
  • Parasitic HF cone and carefully engineered phase plug extend on- and off-axis response
  • Solid bass performance, thanks to usefully high excursion capability (4.6 mm Xmax)
  • Optimized neodymium magnet provides high motor strength
  • Low-mass copper clad aluminum voice coil
  • Copper cap and copper ring on pole piece reduce inductance and distortion
  • Kevlar reinforced paper cone is lightweight yet rigid and well controlled
The Dayton Audio PS Series drivers do it all: true bass, articulate midrange, and balanced, extended highs. An intensive program of design and testing has yielded full-range speakers that feature high sensitivity and smooth response, both on- and off-axis. Although an ideal match for lower powered Class A and Class T designs, the PS180-8 6-1/2" driver's superb resolution and natural sound quality make it a viable option for an even wider variety of applications. The PS Series' audio performance is complemented by the speaker's striking appearance—they look great in dipole and other open back designs, too!
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response48 to 25,000 Hz
  • Sensitivity94.8 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)58.5 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.63 mH
  • Mechanical Q (Qms)3.64
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.33
  • Compliance Equivalent Volume (Vas)1 ft.³
  • Mechanical Compliance of Suspension (Cms)1.05 mm/N
  • BL Product (BL)6.82 Tm
  • Diaphragm Mass Inc. Airload (Mms)7g
  • Maximum Linear Excursion (Xmax)4.6 mm
  • Surface Area of Cone (Sd)132.7 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.09"
  • Baffle Cutout Diameter5.71"
  • Depth3.06"
  • Bolt Circle Diameter6.69"
  • # Mounting Holes6
  • Sealed Volume0.11 ft.³
  • Sealed F3168 Hz
  • Vented Volume0.25 ft.³
  • Vented F3108 Hz
  • BrandDayton Audio
  • ModelPS180-8
  • Part Number295-344
  • UPC844632088797
  • Product CategoryWoofers
    (12 Reviews)
  • Weight2.9 lbs.
View similar products to the Dayton Audio PS180-8 6-1/2" Point Source Full-Range Neo Driver
Videos
