Dayton Audio PM220-8 8" Wideband Midbass Neo Driver
Brand:|Model: PM220-8|Part # 295-345
Dayton Audio designed the PM220-8 8" midbass driver for wide-bandwidth midrange and midbass applications in multi-way speakers.
List Price$164.99
You Save23%
$126.50
Buy 4+$120.50
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 295-345
  • Kevlar-reinforced paper cone for excellent detail
  • Klippel-optimized, high-performance design
  • Wide 43 to 10,000 Hz bandwidth meets high 95 dB sensitivity
  • Perfect complement for ribbon and planar tweeters
  • Powerful neodymium ring motor
The Dayton Audio PM220-8 8" midbass driver is based on the same platform as the acclaimed Point Source full-range drivers, but designed for esoteric high-performance applications requiring an extremely wide-bandwidth midrange or midbass driver. The PM220-8 model provides the ultimate in high-efficiency performance in a variety of system designs, including vented, transmission line, folded horn, or open baffle applications.
The PM Series mid-bass drivers feature ultra-linear Klippel-optimized neodymium motors with copper cap and shorting ring for low distortion, and lightweight, low-loss Kevlar-reinforced paper cones for exceptional detail and high efficiency. The wide bandwidth and extended upper range of these drivers makes them the perfect complement to ribbon and planar-magnetic tweeters.
Check out this PM220-8 Review:
Voice Coil Review - September 2013
  • Nominal Diameter8"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance8 ohms
  • Frequency Response43 to 10,000 Hz
  • Sensitivity95.4 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)49.1 Hz
  • DC Resistance (Re)6.5 ohms
  • Voice Coil Inductance (Le)0.8 mH
  • Mechanical Q (Qms)5.08
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)2.22 ft.³
  • Mechanical Compliance of Suspension (Cms)0.98 mm/N
  • BL Product (BL)7.21 Tm
  • Diaphragm Mass Inc. Airload (Mms)10.7g
  • Maximum Linear Excursion (Xmax)4.6 mm
  • Surface Area of Cone (Sd)205.3 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.72"
  • Baffle Cutout Diameter7.13"
  • Depth3.49"
  • Bolt Circle Diameter8.27"
  • # Mounting Holes6
  • Sealed Volume0.52 ft.³
  • Sealed F3103 Hz
  • Vented Volume1.1 ft.³
  • Vented F362 Hz
  • BrandDayton Audio
  • ModelPM220-8
  • Part Number295-345
  • UPC848791000539
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight4.65 lbs.
View similar products to the Dayton Audio PM220-8 8" Wideband Midbass Neo Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Why does the web page show cms as 1.23 mm/N and the Dayton audio spec sheet say .98 mm/N
Asked by: teater
Dayton is currently in the process of updating specs for all drivers. The specs on their website are going to be the most up to date.
Date published: 2015-06-15
Do you sell a suitable 2-way cabinet for this driver?
Asked by: ElectricRon
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Answered by: GregT
Date published: 2015-05-29
What crossover point and design would you suggest for use with a ribbon tweeter?
Asked by: lmgdvm
Date published: 2014-12-16
I would like to build the biggest enclosures possible, how can I figure this out... using the PS220
Asked by: DH DMAN
Date published: 2014-09-26
Considering as strict mid-bass for doors in my Grand Cherokee. Doors are stabilized,dampened, and nearly sealed. I've had decent mid-bass, even sub-80 Hz bass from current 6.5's, but want more. 75 watts & x-over at Low 100Hz 12db/oct  High 350 Hz 12db/oct
Asked by: Jester
Date published: 2014-07-22
re:I would recommend 1.2 cf with a 2.5" diameter, 5" long port tube for a tuning of 40 Hz. Thx MattP for the reply. I don't have design software. I think internal dimensions of 8.5" x 21.5" X 15" will get me 1.2 cf? Yes? What software do you recommend?
Asked by: RonJon
Those dimensions will give you closer to 1.6 cubic feet. if you cut the depth back to 12" instead of 15" you will have 1.26 which will be about perfect after driver displacement. We use BassBox 6 Pro for our modelling.
Date published: 2014-07-01
  • 2016-02-14T07:41CST
  • co_hasquestionsanswers, tq_12
  • loc_en_US, sid_295-345, PRD, sort_recentQuestionsFirst
