Dayton Audio PK165-8 6" Professional Kevlar/Paper Cone Midrange Speaker
Brand:|Model: PK165-8|Part # 295-020
Dayton Audio's PK165-8 provides high output, extended frequency response, and low distortion—perfect for use in compact full range applications as well as a separate component in multi-way speaker systems.
List Price$41.99
You Save23%
$32.29
Buy 4+$31.17
Part # 295-020
  • High output, low distortion
  • Extended frequency response
  • Kevlar-impregnated paper cone
  • Vented pole piece
  • 1-1/2" aluminum voice coil
Dayton Audio's PK165-8 provides high output, extended frequency response, and low distortion—perfect for use in compact full range applications as well as a separate component in multi-way speaker systems. The PK165-8 features a steel frame, Kevlar-impregnated paper cone, treated cloth surround, vented pole piece, and a 1-1/2" aluminum voice coil wound on a polyimide former.
  • Nominal Diameter6"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance8 ohms
  • Frequency Response95 to 9,000 Hz
  • Sensitivity91.4 dB 2.83V/1m
  • Voice Coil Diameter1.49"
  • Resonant Frequency (Fs)91.5 Hz
  • DC Resistance (Re)6.8 ohms
  • Voice Coil Inductance (Le)0.81 mH
  • Mechanical Q (Qms)7.93
  • Electromagnetic Q (Qes)0.77
  • Total Q (Qts)0.70
  • Compliance Equivalent Volume (Vas)0.27 ft.³
  • Mechanical Compliance of Suspension (Cms)0.3 mm/N
  • BL Product (BL)7.18 Tm
  • Diaphragm Mass Inc. Airload (Mms)10g
  • Maximum Linear Excursion (Xmax)1.5 mm
  • Surface Area of Cone (Sd)113.1 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.5"
  • Baffle Cutout Diameter5.69"
  • Depth2.96"
  • # Mounting Holes4
  • Sealed Volume0.26 ft.³
  • Sealed F3138 Hz
  • Vented Volume0.66 ft.³
  • Vented F367 Hz
  • BrandDayton Audio
  • ModelPK165-8
  • Part Number295-020
  • UPC844632070716
    (10 Reviews)
  • Weight4.2 lbs.
View similar products to the Dayton Audio PK165-8 6" Professional Kevlar/Paper Cone Midrange Speaker
