Dayton Audio PA465S-8 18" Pro Subwoofer 4" VC 8 Ohm
Brand:|Model: PA465S-8|Part # 295-042
Dayton Audio PA Series subwoofers are designed and built to the same standards as popular Italian made pro audio drivers, for solid, reliable bass performance at a fraction of the price. They feature 4" quad-layer voice coils using an inside-outside winding technique, and dual spiders for extra stability.
List Price$298.99
You Save26%
$219.90
Buy 4+$209.90
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
*Domestic US orders only
Part # 295-042
  • 11 mm of Klippel-verified Xmax
  • Inside/outside 4" diameter voice coils for maximum motor efficiency
  • Ultra-rigid Kevlar-paper cones that resist deformation
  • Extensive motor venting for elevated power handling and cool operation
  • Copper shorting ring and pole cap minimize distortion up to the limits of excursion
  • Rugged cast-frame construction with premium materials
With over two decades of high-performance loudspeaker development experience behind them, Dayton Audio PA series subwoofers deliver powerful, dependable bass performance with all of the features and quality of pricey Italian-made pro subwoofers, but at a price that's a whole lot easier on your budget.
Klippel Optimized Motor Structure
The Dayton Audio PA Series subwoofers feature optimized motor structures that provide over 11 mm of Klippel-verified Xmax (10 mm coil overhang) with excellent symmetry and linearity, preventing distortion where it often begins -- in the motor itself. Cleaner bass means higher impact, and better musical detail. The enormous high-grade ceramic magnet is economical yet highly efficient and stable, providing parameters that are a drop-in replacement for most existing pro audio subwoofer enclosures, but a significant upgrade in performance to most OEM drivers. The motor structure also features a copper shorting ring and copper pole cap to reduce flux modulation and inductance distortion, for massively powerful and clean sound at all output levels.
Advanced Cooling and Ventilation
The key to reliable, high-output bass is to get the heat away from the voice coil windings. The PA Series subwoofers feature 4" voice coils that use inside-outside windings, improving heat transfer and reducing power compression. The coils are also wound on fiberglass formers, which are much more resistant to heat-related deformation. Finally, the high-strength motor structures employ extensive venting, below the spider, through the pole piece, and into the gap itself.
Rugged, Reliable Construction
The heavy-duty cones used on the PA Series subwoofers contain a blend of Kevlar and paper fibers, for strength, rigidity, and durability, and the ribbed cone structure provides the necessary stiffness to withstand punishing bass transients. The cone and voice coil assembly is supported by a rugged long-throw suspension featuring dual spiders and a treated and deep-corrugated triple-roll surround, for clean and low-distortion excursion. The cone is coated to withstand incidental exposure to liquid, and the dust cap is anchored by a heavy bead of epoxy for dependable cone integrity. It's all held together by the finest adhesives and a tough cast-aluminum frame that's ready to take some road abuse.
When you're looking for a dependable, heavy-duty subwoofer driver to power your system's low end, choose the PA Series pro subwoofers from Dayton Audio! The 18" model is optimized for maximum deep bass extension in reflex-loaded enclosures. 15" model also available.
  • Nominal Diameter18"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response25 to 1,000 Hz
  • Sensitivity93.9 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)32.3 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)4.98 mH
  • Mechanical Q (Qms)6.92
  • Electromagnetic Q (Qes)0.62
  • Total Q (Qts)0.57
  • Compliance Equivalent Volume (Vas)6.81 ft.³
  • Mechanical Compliance of Suspension (Cms)0.09 mm/N
  • BL Product (BL)21.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)271g
  • Maximum Linear Excursion (Xmax)10 mm
  • Surface Area of Cone (Sd)1,225 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.5"
  • Baffle Cutout Diameter16.7"
  • Depth7.95"
  • Bolt Circle Diameter17.6"
  • # Mounting Holes8
  • Sealed Volume2.64 ft.³
  • Sealed F362 Hz
  • Vented Volume6.38 ft.³
  • Vented F335 Hz
  • BrandDayton Audio
  • ModelPA465S-8
  • Part Number295-042
  • UPC848791001345
    (6 Reviews)
  • Weight34.6500 lbs.
View similar products to the Dayton Audio PA465S-8 18" Pro Subwoofer 4" VC 8 Ohm
