Dayton Audio PA200-8 8" Pro Woofer Speaker
Brand:|Model: PA200-8|Part # 295-025
Dayton Audio's PA200-8 PA Series 8" professional woofer is a great upgrade for musical instrument or sound reinforcement cabinets, and also excels in custom-built speaker systems.
List Price$53.99
Regular Price$41.00
You Save15%
Sale Price
$35.00
Part # 295-025
  • Strong, low-mass carbon fiber impregnated paper cone
  • Low distortion motor system with copper cap
  • Vented pole piece and voice coil gap improve thermal management
  • Black motor parts and black polyimide voice coil former dissipate heat
  • Bumped back plate for unrestricted excursion
The PA200-8 8" professional audio woofer, from Dayton Audio, features high power handling by using a vented pole piece and voice coil gap. Black motor parts (including a black polyimide voice coil) help dissipate heat away from the voice coil and help to minimize power compression.
Extended, smooth frequency response and low distortion are achieved through the use of a powerful 50 ounce ceramic ferrite magnet, combined with a copper cap on the pole piece to reduce stray eddy currents and minimize voice coil inductance.
A strong, low-mass, carbon fiber-impregnated paper cone, together with an I-beam rolled-edge 1.2 mm steel frame provides the rugged durability needed to handle the rigors of touring and for stage use, while still offering the sensitivity and punchy bass that you need.
Dayton Audio's PA Series woofer packs all of these premium features into a value-priced 8" driver that is great for use as an upgrade to sound reinforcement or musical instrument speakers. The PA200-8 also excels in custom-built speakers.
  • Nominal Diameter8"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance8 ohms
  • Frequency Response70 to 9,000 Hz
  • Sensitivity92.4 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Magnet Weight50 oz.
  • Resonant Frequency (Fs)55.2 Hz
  • DC Resistance (Re)6.2 ohms
  • Voice Coil Inductance (Le)1.09 mH
  • Mechanical Q (Qms)6.17
  • Electromagnetic Q (Qes)0.51
  • Total Q (Qts)0.48
  • Compliance Equivalent Volume (Vas)1 ft.³
  • Mechanical Compliance of Suspension (Cms)0.4 mm/N
  • BL Product (BL)9.28 Tm
  • Diaphragm Mass Inc. Airload (Mms)20.5g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)210.4 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.27"
  • Baffle Cutout Diameter7.17"
  • Depth3.82"
  • Bolt Circle Diameter7.95"
  • # Mounting Holes8
  • Sealed Volume0.57 ft.³
  • Sealed F396 Hz
  • Vented Volume1.1 ft.³
  • Vented F348 Hz
  • BrandDayton Audio
  • ModelPA200-8
  • Part Number295-025
  • UPC848791000546
    (11 Reviews)
  • Weight7.25 lbs.
View similar products to the Dayton Audio PA200-8 8" Pro Woofer Speaker
