Dayton Audio PA165-8 6" PA Driver Speaker
Brand:|Model: PA165-8|Part # 295-015
This unit was designed with the goal of the producing the highest possible output from a driver its size. Great for use in small stage monitors, as a midrange in multi-way systems, or even as a hi-fi midbass.
List Price$28.99
Regular Price$21.59
You Save17%
Sale Price
$18.00
Sale Ends7/31/2016
Part # 295-015
  • High power and efficiency for extreme output
  • Perfect for use as a high output midrange or midbass
  • Even hung voice coil to maximize efficiency
  • Naturally damped paper cone and cloth surround
This unit was designed with the goal of the producing the highest possible output from a driver its size. Great for use in small stage monitors, as a midrange in multi-way systems, or even as a hi-fi midbass. Construction includes a steel frame, paper cone, treated cloth surround, vented pole piece and high-power-handling 1-1/2" aluminum voice coil.
  • Nominal Diameter6"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)150 Watts
  • Impedance8 ohms
  • Frequency Response80 to 5,000 Hz
  • Sensitivity92.9 dB 2.83V/1m
  • Voice Coil Diameter1.38"
  • Resonant Frequency (Fs)80.8 Hz
  • DC Resistance (Re)5.15 ohms
  • Voice Coil Inductance (Le)0.54 mH
  • Mechanical Q (Qms)2.19
  • Electromagnetic Q (Qes)0.60
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)0.32 ft.³
  • Mechanical Compliance of Suspension (Cms)0.42 mm/N
  • BL Product (BL)6.33 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.2g
  • Surface Area of Cone (Sd)120.8 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.5"
  • Baffle Cutout Diameter5.69"
  • Depth2.96"
  • # Mounting Holes4
  • Sealed Volume0.17 ft.³
  • Sealed F3139 Hz
  • Vented Volume0.5 ft.³
  • Vented F368 Hz
  • BrandDayton Audio
  • ModelPA165-8
  • Part Number295-015
  • UPC844632000201
    (22 Reviews)
  • Weight4.2 lbs.
View similar products to the Dayton Audio PA165-8 6" PA Driver Speaker
