Dayton Audio ND91-8 3-1/2" Aluminum Cone Full-Range Driver 8 Ohm
Brand:|Model: ND91-8|Part # 290-226
The Dayton Audio ND91-8 3-1/2" Neo-Balanced driver balances low distortion, extended range, and surprising bass impact. Its sophisticated motor design provides the underhung 1" voice coil with extended linear travel within the magnetic field.
List Price$37.99
You Save25%
Buy 10+$26.48
Part # 290-226
  • Low distortion, full-range 65 Hz to 17 kHz performance
  • Rubber-edged black anodized aluminum alloy cone
  • Large excursion capability—5.1 mm Xmax, 25 mm peak
  • Self-shielded Neo-Balanced motor structure with copper alloy shorting ring
  • 1" 4-layer underhung voice coil with polyimide former
  • 30 watts RMS power handling
  • Great for line arrays and micro monitors
Dayton Audio's ND91 aluminum cone full-range drivers are the latest addition to the acclaimed ND Series high output/low distortion neodymium transducers. By increasing the original ND90's voice coil diameter from 3/4" to 1" and adding a copper alloy shorting ring, the ND91-8 features even lower distortion and delivers better bass impact and dynamic range—with peak Xmax up to 25 mm!
This high-BL version further exploits the low distortion characteristics of the Neo-Balanced motor's optimized magnetic field, making the ND91 drivers an excellent choice for full-range point-source speaker enclosures, as well as extremely accurate, high resolution line arrays.
  • Nominal Diameter3-1/2"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response70 to 17,000 Hz
  • Sensitivity82.1 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)70.7 Hz
  • DC Resistance (Re)7.8 ohms
  • Voice Coil Inductance (Le)1.24 mH
  • Mechanical Q (Qms)4.29
  • Electromagnetic Q (Qes)0.53
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)0.05 ft.³
  • Mechanical Compliance of Suspension (Cms)1.05 mm/N
  • BL Product (BL)5.63 Tm
  • Diaphragm Mass Inc. Airload (Mms)4.8g
  • Maximum Linear Excursion (Xmax)5.1 mm
  • Surface Area of Cone (Sd)30.4 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.35"
  • Baffle Cutout Diameter3.01"
  • Depth2.22"
  • Bolt Circle Diameter3.66"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3139 Hz
  • Vented Volume0.04 ft.³
  • Vented F375 Hz
  • BrandDayton Audio
  • ModelND91-8
  • Part Number290-226
  • UPC844632090455
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (9 Reviews)
  • Weight0.7 lbs.
View similar products to the Dayton Audio ND91-8 3-1/2" Aluminum Cone Full-Range Driver 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
