Dayton Audio ND90-8 3-1/2" Aluminum Cone Full-Range Driver 8 Ohm
Brand:|Model: ND90-8|Part # 290-210
Looking for a small driver that punches above its weight class? This radical high performance full-range transducer exudes an aura of superiority.
List Price$27.99
You Save24%
$21.35
Buy 10-49 $18.30
Buy 50+$13.98
Part # 290-210
  • Direct replacement for Aura NS3
  • Rubber-edged anodized aluminum alloy cone
  • Large excursion capability—4 mm Xmax, 20 mm peak
  • Self-shielded Neo-Balanced motor structure
  • Full-range 80 Hz to 15 kHz performance
  • 3/4" 4-layer underhung voice coil with polyimide former
  • 20 watts RMS power handling
Dayton Audio's compact aluminum cone drivers demonstrate the latest advances in high-excursion design processes. An efficient, low-distortion Neo-Balanced motor is combined with a rigid yet lightweight aluminum diaphragm, yielding impressive high-impact audio reproduction. Perfect for single point-source applications, or combined in multiples and line arrays.
  • Nominal Diameter3-1/2"
  • Power Handling (RMS)20 Watts
  • Power Handling (max)40 Watts
  • Impedance8 ohms
  • Frequency Response80 to 15,000 Hz
  • Sensitivity81.4 dB 2.83V/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)70.7 Hz
  • DC Resistance (Re)7.5 ohms
  • Voice Coil Inductance (Le)1.08 mH
  • Mechanical Q (Qms)4.71
  • Electromagnetic Q (Qes)0.75
  • Total Q (Qts)0.65
  • Compliance Equivalent Volume (Vas)0.062 ft.³
  • Mechanical Compliance of Suspension (Cms)1.22 mm/N
  • BL Product (BL)4.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)4.2g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)31.2 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter4.07"
  • Baffle Cutout Diameter3.35"
  • Depth2.39"
  • # Mounting Holes4
  • Sealed Volume0.1 ft.³
  • Sealed F396 Hz
  • Vented Volume0.15 ft.³
  • Vented F350 Hz
  • BrandDayton Audio
  • ModelND90-8
  • Part Number290-210
  • UPC844632077449
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (27 Reviews)
  • Weight0.55 lbs.
