Dayton Audio ND65-8 2-1/2" Aluminum Cone Full-Range Driver 8 Ohm
Brand:|Model: ND65-8|Part # 290-206
Dayton Audio's compact ND65-8 aluminum cone driver demonstrates the latest advances in high-excursion design processes.
List Price$25.99
You Save26%
$19.30
Buy 10+$15.98
Part # 290-206
  • Rubber-edged aluminum alloy cone
  • Large excursion capability
  • Self-shielded Neo-Balanced motor structure
  • 4-layer underhung voice coil with polyimide former
  • High power handling
Dayton Audio's compact ND65-8 aluminum cone driver demonstrates the latest advances in high-excursion design processes. An efficient, low-distortion Neo-Balanced motor is combined with a rigid yet lightweight aluminum diaphragm, yielding impressive high-impact audio reproduction. Perfect for single point-source speaker applications, or combined in multiples and line arrays.
  • Nominal Diameter2-1/2"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response80 to 20,000 Hz
  • Sensitivity80.8 dB 2.83V/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)77.4 Hz
  • DC Resistance (Re)7.4 ohms
  • Voice Coil Inductance (Le)1.04 mH
  • Mechanical Q (Qms)4.01
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)0.02 ft.³
  • Mechanical Compliance of Suspension (Cms)1.68 mm/N
  • BL Product (BL)4.47 Tm
  • Diaphragm Mass Inc. Airload (Mms)2.5g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)15.6 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.5"
  • Baffle Cutout Diameter2.05"
  • Depth2"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3111 Hz
  • Vented Volume0.05 ft.³
  • Vented F355 Hz
  • BrandDayton Audio
  • ModelND65-8
  • Part Number290-206
  • UPC844632081477
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (6 Reviews)
  • Weight0.4 lbs.
