Dayton Audio ND20FB-4 Rear-Mount 3/4" Neodymium Dome Tweeter
Brand:|Model: ND20FB-4|Part # 275-035
This versatile tweeter is a huge step above the average "budget" tweeter. It has the sensitivity, smoothness, and power handling to individually do a two-way with most small woofers.
List Price$18.99
You Save25%
$14.20
Buy 4+$13.28
Part # 275-035
  • Compact neodymium motors have low stray field
  • Ferrofluid enhances power handling and helps damp resonance
  • Rear-mount design minimizes housing size
  • Center-to-center spacing as low as 1-1/2"
  • Great top-end air and sparkle
Don't let the low price fool you! This versatile tweeter is a huge step above the average "budget" tweeter. Conceived with line array thoughts in mind, it is finally possible to achieve the inter-driver spacing needed to minimize comb filtering out to nearly 20 kHz. But its uses don't stop at line arrays-- it has the sensitivity, smoothness, and power handling to individually do a two-way with most small woofers. Or, use it in an A-pillar in your car as a great inexpensive component tweeter. Give them a try for your next budget or micro speaker-- you will be pleasantly surprised!
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter3/4"
  • Impedance4 ohms
  • Power Handling (RMS)15 Watts
  • Frequency Response3,500 to 25,000 Hz
  • Sensitivity90 dB 1W/1m
  • Resonant Frequency (Fs)2,072 Hz
  • DC Resistance (Re)3.20 ohms
  • Voice Coil Inductance (Le)0.03 mH
  • Mechanical Q (Qms)2.08
  • Electromagnetic Q (Qes)3.74
  • Total Q (Qts)1.33
  • Overall Outside Diameter1.54" x 1.54"
  • Depth0.75"
  • BrandDayton Audio
  • ModelND20FB-4
  • Part Number275-035
  • UPC844632000881
  • Product CategoryTweeters
    (24 Reviews)
  • Weight0.1 lbs.
View similar products to the Dayton Audio ND20FB-4 Rear-Mount 3/4" Neodymium Dome Tweeter
in the Tweeters product category.
Dayton Audio ND20FB-4 Rear-Mount 3/4" Neodymium Dome Tweeter is rated 4.3333 out of 5 by 24.
Rated 3 out of 5 by from Don't be fooled by the specs...I was comparing tweeters on the zaph audio website. In terms of specs, that tweeter seemed to be comparable to very high end product. I mean, the frequency response is incredibly flat on a baffle, the tweeter responds very quickly, and the distorsion, well not so bad.We've built the ZDT3.5, which seemed to be a very interesting DIY project. Once we built, we noticed how bad this tweeter was sounding. That's a bit a shame, because there is not so many tweeter that will fit the hole and sound well.Overall, I would say, this is a good tweeter. However, if you're looking to build some high end design (3k$ and more) , I would pass on this one.
Date published: 2015-05-06
Rated 4 out of 5 by from Sounds great for the most partI still have around 35 day to return the product only complaint is a low freq crackle comeing through the 12 uf capacitor.... Any ideas or suggestions??
Date published: 2014-04-04
Rated 5 out of 5 by from Infinity P363 are cheap and no warranty these fixed themMy six month old Infinity P363 have blown the tweeters in all four now, Infinity JBL and Harmon Kardon dont have them and must continue to wait for warranty service three months now. These tweeters can be placed in them and sound better. Stay away from plastic and garbage from Infinity, JBL and Harmon Kardon. They sell but cant service. Thanks to these speakers I have one pair up and running and I will order another set of tweeters for the other pair. ThanksParts-express
Date published: 2013-08-22
Rated 4 out of 5 by from good small tweeterI have used a few of these in different set ups. They have a nice open and airy sound and have decent efficiency despite their size. I am very sad to see the price go up so much on them though.
Date published: 2012-10-07
Rated 4 out of 5 by from MazdaspeedI purchased 2 of these to replace the factory Bose tweeters in my Mazdaspeed 3, after reading others' reviews. There is a noticeable difference and improvement in sound #highs# quality. Obviously not night and day, but enough of a difference that it was worth the approx. $35.00 I spent on the 2 tweeters and the 2 Capacitors.
Date published: 2011-11-16
Rated 4 out of 5 by from Quite goodVery nice little tweeter, but I did notice some sibilance compared to others I've tried. Not to bash it though, it is pretty good and clear.
Date published: 2011-10-13
  • 2016-02-06T06:59CST
  • co_hasreviews, tv_0, tr_24
  • loc_en_US, sid_275-035, PRD, sort_mostRecent
I want to replace the dash speakers in my 2013 Sonata GLS.  Will these fit with minimal rework?
Asked by: dsb2a
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-09-14
Which cap should I use for a 4000Hz xover?
Asked by: okiefz1
I would not recommend only a cap if you need to cross this that low. Even with a second order filter the recommended crossover is no lower than 5,000 Hz. I would recommend the simple high pass filter below.
Date published: 2013-09-17
Does anyone know the cutout size for this tweeter?
Asked by: dewitteridder
For this tweeter in a rear-mount application, you'll want a cutout of about 1-7/16".
Answered by: RussR
Date published: 2013-05-01
  • 2016-02-06T07:57CST
  • loc_en_US, sid_275-035, PRD, sort_recentQuestionsFirst
