Dayton Audio ND140-4 5-1/4" Aluminum Cone Midbass Driver 4 Ohm
Brand:|Model: ND140-4|Part # 290-216
Dayton Audio's compact aluminum cone drivers demonstrate the latest advances in high-excursion design processes.
List Price$39.99
You Save23%
$30.65
Buy 4+$28.80
Part # 290-216
  • Extended-range 54 Hz to 8 kHz performance
  • Rubber-edged aluminum alloy cone
  • Large excursion capability—4 mm Xmax, 20 mm peak
  • Self-shielded Neo-Balanced motor structure
  • 1" 4-layer underhung voice coil with polyimide former
  • 40 watts RMS power handling
Dayton Audio's compact aluminum cone drivers demonstrate the latest advances in high-excursion design processes. An efficient, low-distortion Neo-Balanced motor is combined with a rigid yet lightweight aluminum diaphragm, yielding impressive high-impact audio reproduction. Perfect for single point-source applications, or combined in multiples and line arrays.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance4 ohms
  • Frequency Response54 to 8,000 Hz
  • Sensitivity88.4 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)59.2 Hz
  • DC Resistance (Re)3.7 ohms
  • Voice Coil Inductance (Le)0.79 mH
  • Mechanical Q (Qms)5.35
  • Electromagnetic Q (Qes)0.72
  • Total Q (Qts)0.63
  • Compliance Equivalent Volume (Vas)0.36 ft.³
  • Mechanical Compliance of Suspension (Cms)0.71 mm/N
  • BL Product (BL)3.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)10.1g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)86.6 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter5.5"
  • Baffle Cutout Diameter4.75"
  • Depth2.5"
  • # Mounting Holes4
  • Sealed Volume0.78 ft.³
  • Sealed F365 Hz
  • Vented Volume1 ft.³
  • Vented F334 Hz
  • BrandDayton Audio
  • ModelND140-4
  • Part Number290-216
  • UPC844632081484
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (6 Reviews)
  • Weight1 lbs.
Videos
