Dayton Audio ND105-4 4" Aluminum Cone Midbass Driver 4 Ohm
Brand:|Model: ND105-4|Part # 290-212
Dayton Audio's ND105-4 compact aluminum cone midbass produces high-impact audio demonstrating the latest advances in high-excursion design processes.
OUT OF STOCK
Due In: 8/5/2016
List Price$34.99
You Save23%
$26.90
Buy 10+$23.29
Part # 290-212
  • Extended-range 60 Hz to 10 kHz performance
  • Rubber-edged aluminum alloy cone
  • Large excursion capability—4 mm Xmax, 20 mm peak
  • Self-shielded Neo-Balanced motor structure
  • 1" 4-layer underhung voice coil with polyimide former
  • 30 watts RMS power handling
Dayton Audio's compact aluminum cone drivers demonstrate the latest advances in high-excursion design processes. An efficient, low-distortion Neo-Balanced motor is combined with a rigid yet lightweight aluminum diaphragm, yielding impressive high-impact audio reproduction. Perfect for single point-source applications, or combined in multiples and line arrays.
  • Nominal Diameter4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance4 ohms
  • Frequency Response60 to 10,000 Hz
  • Sensitivity86.8 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)78.7 Hz
  • DC Resistance (Re)3.7 ohms
  • Voice Coil Inductance (Le)0.76 mH
  • Mechanical Q (Qms)7.42
  • Electromagnetic Q (Qes)0.66
  • Total Q (Qts)0.61
  • Compliance Equivalent Volume (Vas)0.069 ft.³
  • Mechanical Compliance of Suspension (Cms)0.55 mm/N
  • BL Product (BL)4.52 Tm
  • Diaphragm Mass Inc. Airload (Mms)7.4g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)51.5 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter4.13"
  • Baffle Cutout Diameter3.66"
  • Depth2.64"
  • # Mounting Holes4
  • Sealed Volume0.1 ft.³
  • Sealed F384 Hz
  • Vented Volume0.3 ft.³
  • Vented F341 Hz
  • BrandDayton Audio
  • ModelND105-4
  • Part Number290-212
  • UPC844632081071
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (28 Reviews)
  • Weight0.8 lbs.
View similar products to the Dayton Audio ND105-4 4" Aluminum Cone Midbass Driver 4 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Videos
