Dayton Audio MTMC-1.0CH 1.0 cu. ft. MTM Curved Speaker Cabinet Cherry
Brand:|Model: MTMC-1.0CH|Part # 302-753
Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and bracing, gluing veneer, and finishing.
List Price$260.02
You Save25%
$195.50
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 302-753
  • Attractive curved-sided design is extremely rigid and reduces diffraction
  • Very rich, real wood cherry veneer
  • 1.010 ft³ net internal volume
  • Exclusive baffle replacement system
  • Magnetic grill fasteners
If you want to create a loudspeaker without investing the time and money building one from scratch, these cabinets are the answer. Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and bracing, gluing veneer, and finishing. Using Dayton Audio speaker cabinets will guarantee superior results every time. 3/4" MDF side and back panel construction is reinforced by a 3/4" MDF "shelf" brace running vertically up the sides and across the top and bottom. The entire cabinet, including the rear, is covered with a very rich, genuine cherry wood veneer with a semi-gloss finish. The baffle is 1" MDF with a black satin finish and rabbeted construction. It offers the flexibility of the B-REX replacement system and comes pre-finished without any driver cutouts. The grill is secured to the baffle by neo magnets in line with the machine screws that fasten the baffle to the enclosure. Two 1/4" holes on the back simplify installation of Dayton Audio knock-in binding posts. Attractive curved-sided design is extremely rigid and solid, with minimized panel resonance. Complete with baffles, hardware, and grills. Add crossover parts, port tubes, damping materials, binding posts, and your drivers to create a complete system rivaling the appearance of the most lavishly presented audiophile speakers.
Dimensions: 22" H x (9" Front, 4.5" Back) W x 14.8" D.
Note: Cabinet dimensions do not include grill
One of the most innovative features is the exclusive Baffle Replacement and EXchange (B-REX) system, which allows the front baffle to be easily removed for prototyping and construction. The satin black finish baffle has 4 pre-drilled holes for machine screws that line up with matching threaded inserts, to secure the baffle to the cabinet. The baffle can be installed or removed an infinite number of times. This is great for initial driver cutouts, allowing the work to take place on a piece of flat stock, rather than on a finished cabinet.
Thanks to the B-REX system, if you are uncertain whether your speakers are complete, the machine screws by themselves can be used to hold the baffle in place. Once you are ready to finalize the design, they then act as clamps too hold the baffle in place while your glue is setting. Blank baffles are available separately, allowing further possibilities in terms of using a single cabinet for multiple pairs of drivers. As you can see, the versatility offered by the B-REX system is unmatched in any other pre-finished cabinet!
  • BrandDayton Audio
  • ModelMTMC-1.0CH
  • Part Number302-753
  • UPC844632059568
  • Product CategoryHi-Fi Speaker Cabinets
    (4 Reviews)
  • Weight29 lbs.
View similar products to the Dayton Audio MTMC-1.0CH 1.0 cu. ft. MTM Curved Speaker Cabinet Cherry
in the Hi-Fi Speaker Cabinets product category.
Dayton Audio MTMC-1.0CH 1.0 cu. ft. MTM Curved Speaker Cabinet Cherry is rated 4.0 out of 5 by 4.
Rated 4 out of 5 by from Great cabinet ...butThese are great cabinets and the outside finish is very nice. My only concern as others have noted is that the internal bracing is poorly fitted. There were large gaps in the seams that extended most of the length. Sometimes as much as an eighth inch wide. I spent a great deal of time filling the gaps to ensure the bracing would be functional. Despite this, the cabinets are still a great value. It would be difficult to build a cabinet like this at even close the price.
Date published: 2013-02-12
Rated 4 out of 5 by from so many uses.This cabinet could have simply so many uses! instead of gluing the front baffle, you could use some f that new silicone tape to seal it use the screws to hold it in place and have multiple baffles with different drivers for party use or casual listening. It is simply a great cabinet. whoever deigned this is a genius.
Date published: 2009-09-13
Rated 4 out of 5 by from Gorgeous and well designed.It all starts when you open the box, well packed and wraped. The cabinet has good weight and a beautiful finish without a flaw. Removing the front baffle, you see a well thoughtout bracing and all joints sealed. The front bolted baffle is a great idea and helps you in the working up of your design. On this tall model it might help to have two bolts added to the mid section of the front baffle.
Date published: 2008-06-10
Rated 4 out of 5 by from Nice cabinetsYou really can't build cabinets like these for the same price.
Date published: 2008-05-03
  • 2016-02-08T06:21CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_302-753, PRD, sort_mostRecent
Can this cab fit an 8" Pyramid studio pro speaker, if so how many plus port and tweeter?
Asked by: CharlesD72681
Due to the round over on the baffle, the useable width of the front of the speaker is about 8". The Studio Pro 8" woofer measures about 8-1/4". If you don't mind a slight overhang on the edge it will work. This cabinet will fit two woofers, I would not recommend porting these.
Date published: 2015-01-19
Wiil a single 8" tand bang driver work in this cabinet?
Asked by: PatShrews
This depends entirely on the specific driver in question. This cabinet has a useable baffle width of 8" as well so this may affect the frame size of the speaker you want to use.
Date published: 2013-10-08
price for 1 cabinet or per pair?
Asked by: laert
These are sold individually.
Date published: 2013-08-09
Is there a photo of the unit with the grill removed?
I was wondering how the front looked minus the grill?
Asked by: Dofus
We don't have a photo with the grill removed however it is just a blank black baffle. The baffle below is the same that is included with this cabinet so this will show you want the front looks like without the grill.
Date published: 2012-10-03
Does the Baffle have holes already drilled?
Asked by: synops74
Could you be a tad more specific? The description mentions 4 pre drilled holes with machine screws to attach the baffle. Are you looking for something else?
Answered by: drjohn
Date published: 2012-02-16
  • 2016-02-08T06:56CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_302-753, PRD, sort_recentQuestionsFirst
