300-430_ALT_0
300-430_ALT_1
300-430_ALT_2
300-430_ALT_3
300-430_ALT_4
300-430_ALT_5
300-430_ALT_6
300-430_ALT_7
300-430_ALT_8
300-430_ALT_9
Dayton Audio ME650C 6-1/2" LCRS 15 degree Angled Ceiling Speaker
Brand:| Model: ME650C
Product Video
What the world really needs are ceiling speakers that sound spectacular, but have a look that's understated – almost invisible. Dayton Audio Micro-Edge coaxial ceiling speakers like the angled ME6500C fill that need like no others on the market.
  • The perfect "all speaker solution" for ceiling mounted home theater systems
  • 15° angle provides cinematic imaging
  • Contemporary Micro-Edge™ design
  • Long-throw 6-1/2" Kevlar® woofer with rubber surround
  • 1" pivoting silk dome tweeter
  • 12 dB/octave optimized crossover
300-430
Weight: 4.85 lbs.
IN STOCK
List Price$76.99
Regular Price$55.95
You Save19%
Sale Price
$44.95
Part # 300-430
Dayton Audio's LCRS ceiling speakers are designed as an "all speaker solution" for ceiling mounted home theater systems. The new Micro-Edge™ design offers a modern look for today's contemporary décor.
 A 15° angle provides cinematic imaging for lifelike sound playback when used in front, center channel, or surround speaker applications. The 6-1/2" woven Kevlar cone woofer provides stunningly warm mids and tight, accurate bass; 1" pivoting silk dome tweeters reproduce clear highs that rival esoteric loudspeakers while allowing adjustment for customizing the soundstage and imaging according to a room's layout.
All Dayton Audio Micro-Edge Series speakers are timbre matched to provide the best possible home theater experience.
Specifications: • Power handling: 35 watts RMS/70 watts max • Impedance: 8 ohms • Frequency response: 50-20,000 Hz • Sensitivity: 87 1W/1m (±3 dB) • Dimensions: 9-7/8" dia. x 5-5/8" D • Cutout size: 8-1/4" dia. • Sold individually.
  • Input Rating8 ohm
  • Mounting StyleIn-ceiling
  • Special FeaturesAngled,Micro Edge Low Profile
  • Woofer Diameter6-1/2"
  • BrandDayton Audio
  • ModelME650C
  • Part Number300-430
  • UPC848791000126
  • Product CategoryCeiling Speakers
    (2 Reviews)
  • Weight4.85 lbs.
View similar products to the Dayton Audio ME650C 6-1/2" LCRS 15 degree Angled Ceiling Speaker
in the Ceiling Speakers product category.
Dayton Audio ME650C 6-1/2" LCRS 15 degree Angled Ceiling Speaker is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from Great bass, nice crossover, ok mountingI've had 5 of these for about a year and they sound great, good bass and solid design. I was previously a home theater installer and must say these are a great speaker for the price and it's what I put in my home. Only gripe is the plastic mounting tabs can be a bit weak if you aren't careful. I'm not sure anyone would be willing to pay more for stronger mounting tabs, but just be very gentle, as I broke a few (4 of 28 some tabs) and jb welded them back together.
Date published: 2014-03-23
Rated 4 out of 5 by from nice projectInstalled these to replace some long time used tower speakers, have nice clear sound , not thumping low end but decent for use as home cinema at moderate volume levels.
Date published: 2014-03-01
I just purchased the 15 deg angled micro edge speaker. I will install it in my ceiling. Do I need to put an enclosure on the back of the speaker? I have it on a work bench and the base is not very noticable until I put the speaker in the stirafoam box
Asked by: Rich1234
These are designed not to need an enclosure but they will require infinite baffle mounting in order to get decent bass response. Having them open on a bench will not provide very good results, the front of the speaker needs to be separated from the back.
Date published: 2014-08-01
What is max thickness of drywall that the mounting clips can accomodate? can I use on double drywall ceiling?
Asked by: jjinc
If you back the screws out you can get about 1-1/4" of clearance for the thickness of the material you are working with.
Date published: 2014-03-05
is the me650c 15 degree speaker and the me620c speaker the same aside for the 15 degree angle of the me650c? are the grills and finished look identical ?
Asked by: jjinc
The grills and finish look identical although the angle speaker is about 1" larger in diameter.
Date published: 2014-03-04
Do these include mounting hardware?  If not, what mounting kit would be best for installation into a finished wall?
Asked by: cory_johannsen
Yes these do have mounting hardware. Simply cut the hole, wire the speaker and mount as per the instructions.
Date published: 2014-02-17
Center Channel
Does Dayton offer a Center Channel ceiling speaker with the micro-edge? i cant find anything and it seems odd to omit this.
Asked by: Torbs
Yes, Dayton does indeed have a matching center channel. The ME520MTM is the matched center channel for this series.
Answered by: Chrisf
Date published: 2014-02-16
Is it wired or wireless? How does it connect to the rest of the sound system?
Asked by: Harry the Greek
These speakers are wired and need to be connected to an amplifier.
Date published: 2013-10-08
Videos
Customer projects that include: Dayton Audio ME650C 6-1/2" LCRS 15 degree Angled Ceiling Speaker
