Dayton Audio MCA3545 Plate Bi-Amplifier
Brand:|Model: MCA3545|Part # 300-775
Dayton Audio's MCA3545 Bi-Amplifier was designed for use in active 2-way loudspeakers for music playback, computer sound systems, and home theater applications.
Comparable Items In Stock:
Part # 300-775
  • Easily adjustable separate low/high amps for improved dynamic range
  • Independent LM3886 output devices
  • Master level control
  • 24 dB/octave low pass and high pass filters
  • User selectable crossover frequencies
  • RCA and XLR line level inputs
  • Signal-dependent auto-on feature
Now with XLR inputs, user selectable crossover points, and more HF power! Dayton Audio's MCA3545 Bi-Amplifier was designed for use in active 2-way loudspeakers for music playback, computer sound systems, and home theater applications. Independent high and low level controls and user-selectable crossover points enable customization to any drivers and listening environment. General Specifications: Selectable crossover points: 2.2 kHz, 3.2 kHz, 3.8 kHz, 4.5 kHz, and 5.2 kHz @ 24 dB/octave • Input voltage: Selectable 115V/230V, fuse protected.
Low Frequency Output Specifications: • Power output: 45 watts RMS @ 8 ohms • Frequency response: 15 Hz-5.2 kHz • THD+N: < 1% @ rated power • S/N ratio: 80 dB. High Frequency Output Specifications: • Power output: 35 watts RMS @ 8 ohms • Frequency response: 2.2 kHz-20 kHz • THD+ N: < 1% @ rated power • S/N ratio: 80 dB. Dimensions: • Overall: 5-3/8" W x 8-5/8" H x 4-1/2" D; Enclosure cutout: 4-5/8" W x 7-3/4" H.
  • BrandDayton Audio
  • ModelMCA3545
  • Part Number300-775
  • UPC844632084683
  • Product CategoryFull-Range Plate Amplifiers
    (3 Reviews)
  • Weight7.3 lbs.
