Dayton Audio MCA2550D 2.1 Channel Class D Amplifier
Brand:|Part # 300-772
The MCA2550D was designed and built to provide years of high quality sound reproduction, and is ideal for use in music playback and home theater systems.
  • Independent low and high frequency amplifiers
  • LF amp: 50 watts RMS, 4 ohms minimum
  • HF amp: 25 watts RMS x 2, 8 ohms minimum
  • Efficient Class "D" technology
  • Master level control
  • Subwoofer level control
  • Variable 12 dB/octave subwoofer crossover
Create a custom 2.1 audio system with a fully-featured amplifier that drives satellite speakers and a mono sub from a single chassis! The MCA2550D was designed and built to provide years of high quality sound reproduction, and is ideal for use in music playback and home theater systems. This compact unit features efficient Class "D" technology, independent amplifiers, selectable subwoofer crossover frequency, auto on/off circuitry, and internal protection against shorted speaker loads, thermal faults, and overload conditions. Subwoofer Output Specifications: *Minimum speaker impedance: 4 ohms *Power output: 50 watts RMS @ 4 ohms *THD: Less than 1% @ rated power *S/N ratio: 90 dB *Variable low pass frequency: 40 Hz to 240 Hz *Bass boost: +3 dB centered at 63 Hz. Satellite Output Specifications: *Minimum speaker impedance: 8 ohms *Power output: 25 watts RMS x 2 @ 8 ohms *Frequency response: 250 Hz – 20 kHz *THD: Less than 1% @ rated power *S/N ratio: 90 dB. Dimensions: *Overall: 5-7/8" W x 10-7/16" H x 4-1/2" D *Enclosure cutout: 4-5/8" W x 9-1/4" H.
  • BrandDayton Audio
  • Part Number300-772
  • UPC844632070181
  • Product CategoryFull-Range Plate Amplifiers
    (7 Reviews)
  • Weight3.05 lbs.
View similar products to the Dayton Audio MCA2550D 2.1 Channel Class D Amplifier
in the Full-Range Plate Amplifiers product category.
