Dayton Audio MCA2250E 2.1 Channel Class D Plate Amplifier
Brand:|Model: MCA2250E|Part # 300-771
The Dayton Audio MCA2250E multi-channel amplifier helps you create a custom 2.1 audio system. It's a fully-featured amp that drives two main speakers and a mono sub from a single chassis!
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$149.99
You Save27%
$108.80
Buy 4+$98.80
Part # 300-771
  • 50W RMS mono subwoofer amplifier
  • 22W RMS x 2 high frequency stereo amplifier
  • Efficient Class D amplifier designs
  • Independent level controls
  • Variable 40~240 Hz 12 dB/octave subwoofer crossover
  • Switchable +3 dB bass boost @ 63 Hz
  • Stereo 3.5 mm and RCA line-level inputs
Dayton Audio created the MCA2250E 2.1-channel plate amplifier for the speaker builder looking to build a custom computer sound system, desktop monitoring system, or space-limited home theater system.
The feature-packed MCA2250E includes everything that you need in an amplifier to make system integration quick and simple: independent level controls, stereo RCA line-level and 3.5 mm inputs, signal sensing auto-on, active 150 Hz, 12 dB/octave satellite speaker high-pass filter, and an adjustable 40 to 240 Hz, 12 dB/octave subwoofer low-pass filter.
Up to 50 watts RMS are available for the subwoofer, and 22W x 2 for the satellite speakers. A set of 5-way binding posts offer plug-and-play satellite speaker connection, while a set of 24" long, 16 AWG subwoofer wires are provided on the rear of the plate amplifier for internal connection to a subwoofer. 115 VAC to 230 VAC world-compatible power input.
Subwoofer Amplifier Specifications:
• Minimum speaker impedance: 4 ohms
• Power output: 50 watts RMS @ 4 ohms
• THD: Less than 0.3% @ rated power
• S/N ratio: 90 dB @ rated power
• Variable low pass frequency: 40~240 Hz, 12 dB/octave
• Bass boost: +3 dB centered at 63 Hz
• 0~5 dB gain adjustment control
Satellite Amplifier Specifications:
• Minimum speaker impedance: 8 ohms
• Power output: 22 watts RMS x 2 @ 8 ohms
• Frequency response: 150 Hz – 20 kHz
Plate Amplifier Features and Specifications:
• 5-way binding post satellite speaker terminals
• 24" 16 AWG subwoofer output wires
• Overall dimensions: 5-7/8" W x 10-7/16" H x 4-1/2" D
• Enclosure cutout: 4-5/8" W x 9-1/4" H
  • BrandDayton Audio
  • ModelMCA2250E
  • Part Number300-771
  • UPC844632095368
  • Product CategoryFull-Range Plate Amplifiers
    (24 Reviews)
  • Weight3.2 lbs.
View similar products to the Dayton Audio MCA2250E 2.1 Channel Class D Plate Amplifier
in the Full-Range Plate Amplifiers product category.
