Dayton Audio MA1240a Multi-Zone 12 Channel Amplifier
Brand:|Model: MA1240a|Part # 300-815
Dayton Audio's MA1240a freestanding, twelve channel amplifier was designed for custom multi-room sound distribution. Its intelligently engineered and versatile design integrates easily into high-end whole house audio systems.
OUT OF STOCK
Due In: 8/31/2016
List Price$649.99
You Save24%
$494.78
Buy 4+$475.00
Part # 300-815
  • Stable Class-AB design delivers superior audiophile sound quality and performance
  • Independent and bus inputs enable unparalleled flexibility
  • Bridgeable channel outputs provide additional power when needed
  • Independent channel gain controls allow the output of each speaker to be perfectly matched
  • Multi-stage protection circuitry for reliability and easy troubleshooting of audio system
  • Temperature controlled cooling fans
  • ENERGY STAR and CE EuP directive compliant, consumes less than 1/2 a watt in standby
The high-density solution to the challenges of multi-room audio
The Dayton Audio MA1240a features a Class-AB output circuit that delivers superior audiophile sound quality and stable performance. Each of your installation's zones can benefit from the MA1240a's clean audio reproduction and exceptional functionality. The MA1240a can be stacked with other audio components and includes removable ears for mounting in standard audio racks (2RU).
You have to feed the machine—and it's easy!
Two common or BUS inputs feed audio signals from standard line-level audio sources to any or all channels. Each of the twelve channels has its own dedicated input and independent level adjustment to provide further flexibility. By simply flipping a single switch, two channels can be bridged to increase the total power output for that zone. This is helpful when extra power is needed in certain areas.
All of the convenience and system status monitoring you could need
The MA1240a's manual, automatic on/off, or triggered 12V input turn-on modes facilitate easy integration into automated systems. For quick and easy troubleshooting of the system, each pair of channels or zones has a bi-color LED to indicate its operational status.
Note: See setup addendum when using in-wall volume controls. You can find this document under "Manuals and Resources" on this page.
Specifications: • Rated power output per channel: 40 watts into 8 ohms, 60 watts into 4 ohms (0.09% THD) • Bridged output: 80 watts into 8 ohms (0.30% THD) • Signal to noise ratio: 105 dB A-weighted • Input impedance: 18K ohms • Input sensitivity: 380 mV • Frequency response: 5 Hz - 72 kHz • Channel crosstalk: 80 dB • Dimensions: 16.7" W x 4" H x 14.25" D (tabletop configuration) • Power requirements: 115/230 VAC, 60/50 Hz • Stand-by power rating: 115V, 0.264W • Weight: 38 lbs.
  • BrandDayton Audio
  • ModelMA1240a
  • Part Number300-815
  • UPC844632081095
  • Product CategoryHome Audio Amplifiers
    (23 Reviews)
  • Weight38.0000 lbs.
View similar products to the Dayton Audio MA1240a Multi-Zone 12 Channel Amplifier
in the Home Audio Amplifiers product category.
Videos
