Dayton Audio LCD60ARM Articulating TV Wall Mount with Tilt 32"-60"
Brand:|Model: LCD60ARM|Part # 182-326
Shadow Mounts from Dayton Audio are manufactured from heavy-duty, durable steel, allowing you to trust them with your HDTV. This TV mount can fit flat screens from 32" - 60".
Part # 182-326
  • Unobtrusive black design shadows most HDTVs perfectly
  • Extends up to 11.8" from the wall
  • ±40° of left to right swivel adjustment, ±15° of tilt adjustment
  • Exclusive Rail Clip™ feature eliminates clumsy set screws
  • Universal mounting—fits most screens
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. Heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. Adding an extension to the popular LCD/plasma tilt mount opens up a new world of installation possibilities and allows an HDTV to adjust to your room—not the other way around. Pull the HDTV out for viewing; push it back against the wall when you're finished. Adjustments are accomplished on the mounting arms by a quick turn of the knob, with no tools required.
The patent-pending design of the Dayton Audio Shadow Mounts' exclusive Rail Clip™ feature eliminates clumsy set screws, while the heavy spring tension holds your television securely in place with simple finger-tip control. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Wall bracket: 20.9" (530 mm) W x 10.3" (262 mm) H • Extension bracket: 32.1" (815 mm) W x 9.4" (240 mm) H • TV bracket: 1.375" (34.9 mm) W x 20.9" (530 mm) H • Swivel adjustment: ±40° • Tilt adjustment: ±15° • Rail Clip attachment • TV to wall distance: 4.6"-11.8" (118-300 mm) • Mounting plate depth: 1-7/16" • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400, 600 x 400 • Maximum weight supported: 100 lbs. (45 kg).
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV Capacity40" to 49"
  • BrandDayton Audio
  • ModelLCD60ARM
  • Part Number182-326
  • UPC844632084638
  • Product CategoryTV Mounts & Brackets
    (10 Reviews)
  • Weight28.35 lbs.
View similar products to the Dayton Audio LCD60ARM Articulating TV Wall Mount with Tilt 32"-60"
in the TV Mounts & Brackets product category.
