Dayton Audio ISO-4C Black Chrome Isolation Cone Set 4 Pcs.
Brand:|Model: ISO-4C|Part # 240-721
Attractive solid brass cones effectively isolate components from vibration caused by speakers. May be used on components such as CD players, turntables, tape decks, and more.
List Price$38.99
You Save24%
$29.70
Buy 4-49 $28.90
Buy 50+$24.50
Part # 240-721
  • Attractive black chrome plated solid brass cones
  • Effectively isolate components from vibration caused by speakers
  • Set contains 4 height adjustable cones, 4 flat receptacles, 8 foam cushions
  • Used on components such as CD players, turntables, tape decks, and more
Attractive solid brass cones with black chrome plating effectively isolate components from vibration caused by speakers. May be used on components such as CD players, turntables, tape decks, and more. Set contains 4 height adjustable cones, 4 flat receptacles, 8 foam cushions. • Dimensions: 1" diameter, 1-3/16" high (including disc).
  • BrandDayton Audio
  • ModelISO-4C
  • Part Number240-721
  • UPC844632019081
  • Product CategoryIsolation Cones
  • Unit of MeasurePK
    (11 Reviews)
  • Weight0.88 lbs.
View similar products to the Dayton Audio ISO-4C Black Chrome Isolation Cone Set 4 Pcs.
in the Isolation Cones product category.
Dayton Audio ISO-4C Black Chrome Isolation Cone Set 4 Pcs. is rated 4.8182 out of 5 by 11.
Rated 5 out of 5 by from Quality itemVery well made and work perfectly under my turntable.
Date published: 2014-10-22
Rated 5 out of 5 by from Finally leveled the Rega P3!!My equipmebnt is on a table constructed of 3/4" MDF and Uni-Strut. The turntable sits on my new isolation cones, which rest on two pieces of 1 1/2'' granite strips, isolated from the MDF table by strips of heavy indoor/outdoor carpet. Not only was I finally able to COMPLETELY level the Rega P3 table, but my JBL 4430's have introduced ZERO vibration into the turntable !!! Very pleased !!
Date published: 2014-04-30
Rated 5 out of 5 by from Product did exactly what I expectedI needed this product as spikes under a Sunfire 8" cube subwoofer. The SW had no threads in the base and the manufacturer of the SW recommended that I not drill holes in the base of Sunfire SW. The Dayton Audio isolation cone set comes with double sided sticky pads that attached the spikes to the base of my SW in all of one minute and performed exactly as I had hoped. The spikes are extremely well machined and the adjustable height was a bonus.
Date published: 2011-12-30
Rated 4 out of 5 by from Good product at great price but....Very nicely made product and the price is great. However, the foam rubber pads on each end pieces as seen on the product picture are sort of flimsy... I had to reposition my equipment, and the foam rubber pads were completely flattened and therefore sticking to the equipment... This is the only flaw, but at this price, still well worth it...
Date published: 2008-12-27
Rated 4 out of 5 by from great valueThis is a very well crafted product. Finding a location under your components can be difficult. I used these under my OPPO dvd which has weird feet built in and I needed a work around.
Date published: 2008-01-21
Rated 5 out of 5 by from Does the trick without spending an arm and a legIf you don't have hundreds of dollars to spend on fancy isolation platforms these babies do the trick. Easy to apply and strudy enough to handle large components.
Date published: 2007-12-01
  • 2016-02-06T07:15CST
  • co_hasreviews, tv_0, tr_11
  • loc_en_US, sid_240-721, PRD, sort_mostRecent
Are there isolation cones available that can screw into a component, e.g. amp or pre-amp?
I realize that each manufacturer may use different sized screws to fasten their "feet" so this may add cost. Yet, there still may be some degree of standardized among American and foreign manufacturers (metric).
Asked by: RonG
We have spikes available that have M6 threads intended for speakers although they are not isolation cones. The foam adhesive pads are what isolate the vibrations.
Date published: 2013-01-22
What is the way that these attach to a speaker?
Asked by: cheese
This product is designed to support turntables, CD players, and the like, not speakers. For speakers, you'd want to look into speaker spikes. I've linked a few sets below for your convenience.
Answered by: RussR
Date published: 2011-07-15
How is Hight it in cm, including disc?
Asked by: DanRobo
With the disc, the height is 38mm. The cone itself is 35mm at maximum height.
Answered by: RussR
Date published: 2011-07-01
  • 2016-02-06T08:42CST
  • loc_en_US, sid_240-721, PRD, sort_recentQuestionsFirst
