300-680_ALT_0
300-680_ALT_1
300-680_ALT_2
300-680_ALT_3
300-680_ALT_4
Dayton Audio HTS-1200B Home Theater Speaker Set Black
Brand:| Model: HTS-1200B
Dayton Audio’s home theater systems are engineered to provide excellent clarity and detail for use in any audio application. These speakers are capable of much bigger sound than their small size suggests. A 3-way center channel is key to the design.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
  • Excellent clarity and detail
  • Optimized long-excursion woofers
  • Magnetically shielded to prevent interference with TV screens and computer monitors
  • Black finish blends with any decor
300-680
Weight: 15 lbs.
IN STOCK
List Price$168.99
You Save23%
$129.48
Buy 4-up$119.59
Part # 300-680
Dayton Audio’s HTS-1200B home theater system is designed to be unobtrusive while providing excellent clarity and detail. The smooth blending of their optimized long-excursion woofers and poly dome tweeters is the key to their outstanding performance. Consistent voicing is presented by the satellite and center channel speakers, and they work great with Dayton Audio subwoofers. Contemporary black finish styling allow them to blend in with any decor, while the weather-resistant design means they can be used indoors or out. Included brackets and rubber feet facilitate stand-mounted, wall-mounted, or free standing operation. Includes speaker wire (5 x 12 ft. lengths of 2 x 22 AWG construction), four satellite speakers, and one center channel.
Specifications: SAT Satellite Speakers: • Woofer: 3-3/4" poly with rubber surround • Tweeter: 5/8" polycarbonate ferrofluid cooled • Power handling: 50 watts RMS/80 watts max • Impedance: 8 ohms • Frequency response: 100-20,000 Hz • SPL: 87 dB 1W/1m • Dimensions: 7-1/2" H x 4-1/2" W x 5-1/4" D.
CCS-33 Center Channel: • Woofer: Two 3-3/4" poly with rubber surrounds • Tweeter: 5/8" polycarbonate ferrofluid cooled • Supertweeter: 5/8" piezo • Power handling: 80 watts RMS/120 watts max • Impedance: 8 ohms • Frequency response: 100-20,000 Hz • SPL: 87 dB 1W/1m • Dimensions: 4-1/2" H x 12-1/2" W x 6" D.
  • BrandDayton Audio
  • ModelHTS-1200B
  • Part Number300-680
  • UPC844632055003
  • Product CategoryHome Theater Speaker Systems
    (32 Reviews)
  • Weight15 lbs.
View similar products to the Dayton Audio HTS-1200B Home Theater Speaker Set Black
in the Home Theater Speaker Systems product category.
Dayton Audio HTS-1200B Home Theater Speaker Set Black is rated 4.4688 out of 5 by 32.
Rated 4 out of 5 by from Great Value!I had a home built sub and front speakers, so, this fit the bill perfectly to complete a surround system. I sent two of the speakers out to the deck, and used the center channel and a pair of the satellites to result in 5.1. Since wide frequency response is not so critical in those uses, these speakers worked just fine. I would never consider using a pair of these as primary front speakers though.
Date published: 2014-09-13
Rated 4 out of 5 by from one box solutionThese speakers are very good at sound for movies as well as some music listening. Along with a sub they are better than most speaker packages that are 2 or 3 times the price.
Date published: 2011-12-19
Rated 4 out of 5 by from Decent for a small budget and tight WAF.I bought a set of these to go with a Dayton 12 inch subwoofer and a Pioneer VSX521-K for my brother-in-law. He isn't an audio nut, but he wanted surround sound and I couldn't stand the thought of my sister buying one of those Coby HTIB from Wal-Mart. They live in a Condo and won't be moving any time too soon, so the volume demands aren't super high, and combined with the very strict standards of "cuteness" required by his wife, these fit the bill. They sound solid, but aren't "amazing", and and since they are used for surround sound WITH a sub, they work. The crossover has to be set pretty high. So high, in fact, that I think the 10" Dayton MAY have been a better choice. I found that I had to set it to 180hz to fill in right, otherwise they sound too hollow. If I was looking for speakers on a tight budget and the WAF wasn't such an issue, I would have gone with 4 of the Dayton B652's and a different center, which wouldn't have cost TOO much more, but these are so small and clean looking that they pass muster with the wife.OVERALL:Better than the low end HTIB speakers, but not "audiophile" by any stretch. I would rank them close to my Dad's old Bose cubes from the 90's, before he upgraded to Klipsch. These simply won't cut it without a subwoofer, so don't even think about it...
Date published: 2011-12-12
Rated 5 out of 5 by from Great speakers for the priceI was remodeling my house and needed smaller, but high performing speakers. I saw the price, and took a chance, and l couldn't be happier. Despite the small size, the speakers handle the full range of sound quite well. I use my home theater setup for music too, and have found no issues. The center channel absolutely rocks! I will be buying more products from parts express.
Date published: 2011-11-22
Rated 5 out of 5 by from Great sound for the money!These speakers put out a great clean and crisp sound, they deffinitly need a sub as they dont put out any lows with my sub turned off. I have them running through an Onkyo 260.Con: the only thing that annoyed me was I had to drill out the hole on the mounts to use the screws that came with the kit. I didnt want to use a smaller screw since I wanted them to stay stable on the walls
Date published: 2011-04-08
Rated 5 out of 5 by from Impressive performance even if you're not on a limited budget.I'm very grateful to have a generous father who often upgrades to the latest and greatest, blessing me with a myriad of free "outdated" electronic devices. He had recently given me his "old" Denon AVR-2805 receiver and 1st generation PS3/BlueRay so naturally I had to buy my own 5.1 speakers on a budget. I'm 31 years old, just purchased a new house and car last year with my girlfriend and her two children so you see where this impedes our budget for luxuries such as 5.1 surround sound systems.I bought these based on the positive reviews and some good experiences with Parts Express in the past. I must say it's a very powerful package for little money. We also purchased the Sanus HTB7 stands and they work great together (#240-818).The speakers are best used with a subwoofer in 5.1 configuration. I also needed a powered sub on a budget and built one for a little over $200 using an Alphasonik 10" dual voice coil driver, a Goldwood vented car subwoofer box (#260-628), and a Dayton Audio SA240 plate amplifier (#300-804). You can see my reviews for both of those products under "Perfect amp/box for my ghetto home theater sub!"The whole system sounds very crisp and detailed with exceptional imaging and separation. Especially when driven by a decent amp with some juice. Even better if you have a receiver that can cut off the frequencies below 100hz like the Denon I'm using. Transformers 2 on BlueRay sounds incredible! The lower mids could be a little better but that's to be expected in a speaker this size. Even so, this package will not disappoint you even if budget isn't much of a concern.I'm no stranger to Hi-Fi systems or pro audio recording gear so I'm confident in saying I know good sound when I hear it. I also own a pair of ADAM Audio A7 monitors for my home studio. These Daytons are very good speakers and an excellent value for the whole package. Just remember to add a powered sub to get the full effect.
Date published: 2011-02-20
  • 2015-02-28T06:24CST
  • co_hasreviews, tv_0, tr_32
  • loc_en_US, sid_300-680, PRD, sort_mostRecent
Do these come in white or can I paint them?
Asked by: WackWack
These are only available in black. You could paint them, but I would recommend removing the grills to paint, and masking off the front of the speaker for protect the drivers.
Date published: 2014-11-17
Is the grill on these speakers removable? Will I accomplish better audio using 16 or 14 gauge wire instead of the 22 gauge?
Asked by: Lewis54
The grill is glued in place so removing it will likely cause damage to the grill. A thicker wire gauge will not be beneficial in terms of audio quality. It may be beneficial if you have longer runs to the speakers, although there is no reason to use anything bigger than 16 gauge. Even 18 will be perfectly suitable for most applications.
Date published: 2014-07-01
I have a receiver that delivers 90 watts rms per channel.. Will these speakers be able to handle that? Do I just have to keep the volume down?
Asked by: dukejsh
The receiver should either have a large/small speaker setting or a high pass filter to block low frequencies to the main speakers. You want the filter set around 100 Hz or the main speakers set to "small" in order to not over power them.
Date published: 2014-05-30
I blew my right front speaker. Is it possible to buy just one speaker?
Asked by: tj_metcalf
Unfortunately we only offer these in pairs.http://www.parts-express.com/dayton-audio-sat-bk-satellite-speaker-pair-black--300-670
Date published: 2014-03-27
Why would the center channel cut out after a few minutes?
Works for the first couple minutes of a movie, and then goes "flat" like the tweeter has a sock stuffed in it. I've checked, and did not find any socks in the speaker...I have the speakers connected to a Yamaha V800 reciever. I've tried an Advent Heritage as a center channel test, and it worked fine. Any thoughts? anyone?
Asked by: riggomatic
It sounds to me like you received a defective center channel speaker, and I certainly apologize for that. Please contact us at 1-800-338-0531 or tech@parts-express.com so we can arrange to get a replacement sent out at no cost to you.
Answered by: RussR
Date published: 2014-02-03
Photos/description of brackets?
I'm interested in what the brackets for these Dayton Audio HTS-1200B Home Theater Speakers are like. All the description says is wall-mount. Where do they attach on the speakers, can the speakers pivot/rotate on the brackets? Are they appropriate for some ceiling mount applications? Can anyone provide a description or photo of the brackets?
Asked by: cganoe
These speakers feature a swivel wall mount brackets that are not designed for ceiling mount applications. The surround speakers swivel side-to-side and feature a single keyhole slot. The center channel tilts up and down and features two keyhole slots. The brackets attach via a brass insert. See the attached images.Dayton Audio has an optional ball-and-socket mount that would attach via the brass insert. This mount would allow you to ceiling mount these speakers. See the attached image.
Answered by: mikevv
  • 2015-02-28T08:15CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_300-680, PRD, sort_recentQuestionsFirst
Customer projects that include: Dayton Audio HTS-1200B Home Theater Speaker Set Black
