Dayton Audio HF13C27 23.1 ft. High-Speed Flat HDMI Cable
Brand:| Model: HF13C27
Dayton Audio's flat, high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. The flat design reduces the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b.
Which length will work best for you?
1.65 ft. Dayton Audio High-Speed Flat HDMI Cable3.3 ft. Dayton Audio High-Speed Flat HDMI Cable6.6 ft. Dayton Audio High-Speed Flat HDMI Cable9.9 ft. Dayton Audio High-Speed Flat HDMI Cable16.5 ft. Dayton Audio High-Speed Flat HDMI Cable23.1 ft. Dayton Audio High-Speed Flat HDMI Cable33 ft. Dayton Audio High-Speed Flat HDMI Cable
  • Supports resolutions up to 1600p, refresh rates up to 240 Hz, and 48-bit Deep Color
  • Flat cable construction reduces cable footprint while reducing cross-talk
  • HDCP compliant for protected content playback such as Blu-ray
  • ATC certified HDMI v1.3b Category 2
181-794
Weight: 1.28 lbs.
IN STOCK
List Price$55.99
You Save66%
$18.63
Buy 4-up$17.70
Part # 181-794
Dayton Audio's high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. Unleash the full potential of high definition 1080p video and lossless Dolby® TrueHD or DTS-HD Master Audio™ formats. Shielded, 28AWG twisted-pair oxygen-free conductors make this cable ideal for permanent installations. All connector contact surfaces are plated with 24 karat gold to provide a lifetime of reliable service. The flat design of these HDMI cables further separates the cable pairs reducing the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b compliance, as well as faster 340 MHz (10.2 Gbps) performance. Support for 240 Hz refresh rates, Lip Sync audio/video synchronization and future-proofing for monitors able to display up to a 1600p resolution is built-in.
No Questions Asked Lifetime Warranty
  • Cable TypeHDMI Male to Male
  • Cable Length23 ft.
  • HDMI Version1.3
  • Wire Gauge28 AWG
  • Jacket ColorBlack
  • Special FeaturesCL2 Rated,Flat
  • BrandDayton Audio
  • ModelHF13C27
  • Part Number181-794
  • UPC844632071065
  • Product CategoryHDMI Cables
  • Weight1.28 lbs.
View similar products to the Dayton Audio HF13C27 23.1 ft. High-Speed Flat HDMI Cable
in the HDMI Cables product category.
Is this cable capable of carrying 3D signal well?
Asked by: pbrykailo
Unfortunately this is only v1.3b so it will not handle 3D.
Date published: 2014-01-06
rated for in-wall installations (commercial)?
Asked by: ArtisanHB
Generally, no. Codes vary dramatically. You need to check with your local construction codes to see what is allowable in the location of your project. Typically you need CL3 rated wiring. If you do not build to code and an "incident" occurs, insurance may not pay, and a property may not be insurable - at least without an exception clause.
Answered by: MarkAJH
Date published: 2012-06-27
Customer projects that include: Dayton Audio HF13C27 23.1 ft. High-Speed Flat HDMI Cable
