Dayton Audio HF13C25 16.5 ft. High-Speed Flat HDMI Cable
Brand:| Model: HF13C25
Dayton Audio's flat, high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. The flat design reduces the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b.
This High-Speed Flat HDMI Cable is available in the following lengths:
1.65 ft.   3.3 ft.   6.6 ft.   9.9 ft.   16.5 ft.   23.1 ft.   33 ft.
  • Supports resolutions up to 1600p, refresh rates up to 240 Hz, and 48-bit Deep Color
  • Flat cable construction reduces cable footprint while reducing cross-talk
  • HDCP compliant for protected content playback such as Blu-ray
  • ATC certified HDMI v1.3b Category 2
181-792
Weight: 0.92 lbs.
IN STOCK
List Price$41.99
You Save66%
$13.89
Buy 4-up$13.19
Part # 181-792
Dayton Audio's high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. Unleash the full potential of high definition 1080p video and lossless Dolby® TrueHD or DTS-HD Master Audio™ formats. Shielded, 28AWG twisted-pair oxygen-free conductors make this cable ideal for permanent installations. All connector contact surfaces are plated with 24 karat gold to provide a lifetime of reliable service. The flat design of these HDMI cables further separates the cable pairs reducing the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b compliance, as well as faster 340 MHz (10.2 Gbps) performance. Support for 240 Hz refresh rates, Lip Sync audio/video synchronization and future-proofing for monitors able to display up to a 1600p resolution is built-in.
No Questions Asked Lifetime Warranty
  • Cable TypeHDMI Male to Male
  • Special FeaturesFlat
  • Cable Length16.4 ft.
  • Jacket ColorBlack
  • BrandDayton Audio
  • ModelHF13C25
  • Part Number181-792
  • UPC844632071058
  • Product CategoryHDMI Cables
    (1 Reviews)
  • Weight0.92 lbs.
View similar products to the Dayton Audio HF13C25 16.5 ft. High-Speed Flat HDMI Cable
in the HDMI Cables product category.
Dayton Audio HF13C25 16.5 ft. High-Speed Flat HDMI Cable is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Works like a charm!Fits into tight spaces other HDMI cables can't go. Lays neatly against the walls. Excellent picture and audio.
Date published: 2012-05-09
I need to buy a cable that has HDMI connections at both sides to connect a laptop to our TV. I need about 15-20 feet long. Which part numbers work?
I just want to make sure I don't order something which has an HDMI on one side but some other type of connection on the other side. Thanks! PS: I sure enjoy having Part Express to go to! Harry Cole in Phoenix
Asked by: Touch
This cable will work fine for that application, any standard HDMI cable will do the trick. If the cable has two different connectors the title or description will state this.
Date published: 2013-10-15
Customer projects that include: Dayton Audio HF13C25 16.5 ft. High-Speed Flat HDMI Cable
