Dayton Audio HF13C23 9.9 ft. High-Speed Flat HDMI Cable
Brand:| Model: HF13C23
Dayton Audio's flat, high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. The flat design reduces the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b.
This High-Speed Flat HDMI Cable is available in the following lengths:
1.65 ft.   3.3 ft.   6.6 ft.   9.9 ft.   16.5 ft.   23.1 ft.   33 ft.
  • Supports resolutions up to 1600p, refresh rates up to 240 Hz, and 48-bit Deep Color
  • Flat cable construction reduces cable footprint while reducing cross-talk
  • HDCP compliant for protected content playback such as Blu-ray
  • ATC certified HDMI v1.3b Category 2
181-790
Weight: 0.56 lbs.
IN STOCK
List Price$24.99
You Save67%
$8.17
Buy 4-up$7.76
Part # 181-790
Dayton Audio's high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. Unleash the full potential of high definition 1080p video and lossless Dolby® TrueHD or DTS-HD Master Audio™ formats. Shielded, 28AWG twisted-pair oxygen-free conductors make this cable ideal for permanent installations. All connector contact surfaces are plated with 24 karat gold to provide a lifetime of reliable service. The flat design of these HDMI cables further separates the cable pairs reducing the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b compliance, as well as faster 340 MHz (10.2 Gbps) performance. Support for 240 Hz refresh rates, Lip Sync audio/video synchronization and future-proofing for monitors able to display up to a 1600p resolution is built-in.
No Questions Asked Lifetime Warranty
  • Cable TypeHDMI Male to Male
  • Special FeaturesFlat
  • Cable Length10 ft.
  • Jacket ColorBlack
  • BrandDayton Audio
  • ModelHF13C23
  • Part Number181-790
  • UPC844632071041
  • Product CategoryHDMI Cables
    (4 Reviews)
  • Weight0.56 lbs.
View similar products to the Dayton Audio HF13C23 9.9 ft. High-Speed Flat HDMI Cable
in the HDMI Cables product category.
Dayton Audio HF13C23 9.9 ft. High-Speed Flat HDMI Cable is rated 4.75 out of 5 by 4.
Rated 4 out of 5 by from Nice flat HDMI cableSeems to work well and different lengths allow for cleaner setups. Just wish HDMI (in general) had a more solid connection or "snap" to the connection since all of them seem to sneak out of the plug under tension. Using them in my current setup.
Date published: 2013-09-30
Rated 5 out of 5 by from flat hdmi cablethis is the best hdmi cable i have ever used it creates a wonderful picture on your tv. i highly recomend this cable. thanks parts express for this great product
Date published: 2012-04-06
Rated 5 out of 5 by from Use it. It is EXCELLENTPut to use immediately attached to Home Theatre. Great response and the length and the fact that it is flat was a life saver.
Date published: 2012-03-07
Rated 5 out of 5 by from Exceptional ProductI purchased this particular HDMI cable for the obvious reason of being flat. My current setup requires multiple cables from the TV to various components. The flat HDMI was easily snaked through the walls and out my cable plates. The video quality is equivalent to Monster cable. I ve used Dayton cables in past with no issues. My only gripe would be about the connection not fitting snug into the ports. This was easily fixed by taping a small portion of cable to my TV (back of TV); otherwise any type of slight tension would yank the cable from the ports while mounting or staging cables etc.
Customer projects that include: Dayton Audio HF13C23 9.9 ft. High-Speed Flat HDMI Cable
