Dayton Audio HF13C22 6.6 ft. High-Speed Flat HDMI Cable
Brand:| Model: HF13C22
Dayton Audio's flat, high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. The flat design reduces the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b.
Which length will work best for you?
1.65 ft. Dayton Audio High-Speed Flat HDMI Cable3.3 ft. Dayton Audio High-Speed Flat HDMI Cable6.6 ft. Dayton Audio High-Speed Flat HDMI Cable9.9 ft. Dayton Audio High-Speed Flat HDMI Cable16.5 ft. Dayton Audio High-Speed Flat HDMI Cable23.1 ft. Dayton Audio High-Speed Flat HDMI Cable33 ft. Dayton Audio High-Speed Flat HDMI Cable
  • Supports resolutions up to 1600p, refresh rates up to 240 Hz, and 48-bit Deep Color
  • Flat cable construction reduces cable footprint while reducing cross-talk
  • HDCP compliant for protected content playback such as Blu-ray
  • ATC certified HDMI v1.3b Category 2
181-788
Weight: 0.38 lbs.
IN STOCK
List Price$21.99
You Save66%
$7.29
Buy 4-up$6.92
Part # 181-788
Dayton Audio's high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. Unleash the full potential of high definition 1080p video and lossless Dolby® TrueHD or DTS-HD Master Audio™ formats. Shielded, 28AWG twisted-pair oxygen-free conductors make this cable ideal for permanent installations. All connector contact surfaces are plated with 24 karat gold to provide a lifetime of reliable service. The flat design of these HDMI cables further separates the cable pairs reducing the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b compliance, as well as faster 340 MHz (10.2 Gbps) performance. Support for 240 Hz refresh rates, Lip Sync audio/video synchronization and future-proofing for monitors able to display up to a 1600p resolution is built-in.
No Questions Asked Lifetime Warranty
  • Cable TypeHDMI Male to Male
  • Cable Length6.6 ft.
  • HDMI Version1.3
  • Wire Gauge28 AWG
  • Jacket ColorBlack
  • Special FeaturesCL2 Rated,Flat
  • BrandDayton Audio
  • ModelHF13C22
  • Part Number181-788
  • UPC844632071034
  • Product CategoryHDMI Cables
    (10 Reviews)
  • Weight0.38 lbs.
View similar products to the Dayton Audio HF13C22 6.6 ft. High-Speed Flat HDMI Cable
in the HDMI Cables product category.
Dayton Audio HF13C22 6.6 ft. High-Speed Flat HDMI Cable is rated 4.4 out of 5 by 10.
Rated 5 out of 5 by from Nice N ClearJust An awsume cable At an unbelevable price. I have been giving them away for christmas. Gave one to my brother for his X box 360 he went for composit viedo to HDMI he was speach less Call of Duty Black Ops look amazing on his 50" panisonic 600hz 1080p plazma set you could see all of the details just amazing.
Date published: 2010-12-27
Rated 2 out of 5 by from Cumbersome unless length exactly fits your needI bought a pair of these, and now expect to stop using both. The reason is that in my setup, there is no way to hide cables other than contain them within a bundle as best I can and wrap the bundle in velcro ties and tie the bundle against the rear upright of the open rack that I use for my gear. Cables are virtually never the perfect length, which means that I carefully and neat coil up the excess at one end or the other and place it as neatly as I can, behind on the components. With this cable, it does not easily accommodate the bundling, but the bigger problem is that there is no easy way to deal with the excess. You can make a flat coil of it, but because of the stiffness, the coil will be larger than it typically would be if it were a round cable, and aside from that, one end of the cable has to exit from within the center of that coil. Then that end has to twist around in order to make the connection at the component. There just isn't any way to get the cable to cooperate unless either (1.) it happens to be exactly the right length for your setup, or (2.) you use a cabinet of some sort where you can let all the extra cable just hang behind the cabinet.
Date published: 2010-06-01
Rated 4 out of 5 by from Great quality - does the job wellThe flat cable is just the trick for certain installations. Sturdy construction and great performance.
Date published: 2010-03-28
Rated 5 out of 5 by from Research pays offI recently recieved a Blue Ray player as a gift. Already having the 52" HD TV, I was urged to purchase a "quality" HDMI cable. I was told what features I needed, and handed a, lets say a "Monsterously" good cable for up over $100. Found not only a comparable, but higher rated cable for less than 10% of the "Monsterously" good cable (including shipping). I'm extremely satisfied with the quality, and especially the price.
Date published: 2010-01-26
Rated 5 out of 5 by from Superb High Speed HDMI CableI just bought 3 of these for my HT system. I just added a BD player and a HT receiver that accepted 4 HDMI cables. One of these cables replaced a "stock" HDMI cable that came with my satellite recevier. IMHO, there was a noticable difference on HD broadcasts. Even the non-HD siganls seemed to be crisper; at least with my eyes. One of these cables also replaced an older Dayton Signature HDMI cable. Because this cable was advertised as high speed and because it is advertised as a v1.3b compliant, I replaced the Siganture cable. If there is a difference I can't see or hear it. Construction wise, I think the Siganture cable is better, but then list price wise, the Siganture cable costs 2 1/2 times more. I believe all of the Dayton HDMI cables are far superior to brand "M", and obviously much less expensive.
Date published: 2010-01-01
Rated 4 out of 5 by from Very Good ValueProduct provides very good value for the money. The picture is equivalent to the more expensive monster cable I was persuaded to purchased to complete my system. I will buy the Dayton again.
Date published: 2009-03-29
Customer projects that include: Dayton Audio HF13C22 6.6 ft. High-Speed Flat HDMI Cable
