Dayton Audio HF13C210 33 ft. High-Speed Flat HDMI Cable
Brand:| Model: HF13C210
Dayton Audio's flat, high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. The flat design reduces the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b.
Which length will work best for you?
1.65 ft. Dayton Audio High-Speed Flat HDMI Cable3.3 ft. Dayton Audio High-Speed Flat HDMI Cable6.6 ft. Dayton Audio High-Speed Flat HDMI Cable9.9 ft. Dayton Audio High-Speed Flat HDMI Cable16.5 ft. Dayton Audio High-Speed Flat HDMI Cable23.1 ft. Dayton Audio High-Speed Flat HDMI Cable33 ft. Dayton Audio High-Speed Flat HDMI Cable
  • Supports resolutions up to 1600p, refresh rates up to 240 Hz, and 48-bit Deep Color
  • Flat cable construction reduces cable footprint while reducing cross-talk
  • HDCP compliant for protected content playback such as Blu-ray
  • ATC certified HDMI v1.3b Category 2
181-796
Weight: 1.5000 lbs.
IN STOCK
List Price$79.99
You Save66%
$26.43
Buy 4-up$25.11
Part # 181-796
Dayton Audio's high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. Unleash the full potential of high definition 1080p video and lossless Dolby® TrueHD or DTS-HD Master Audio™ audio formats. Shielded, 28AWG twisted-pair oxygen-free conductors make this cable ideal for permanent installations. All connector contact surfaces are plated with 24 karat gold to provide a lifetime of reliable service. The flat design of these HDMI cables further separates the cable pairs reducing the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b compliance, as well as faster 340 MHz (10.2 Gbps) performance. Support for 240 Hz refresh rates, Lip Sync audio/video synchronization and future-proofing for monitors able to display up to a 1600p resolution is built-in.
No Questions Asked Lifetime Warranty
  • Cable TypeHDMI Male to Male
  • Cable Length33 ft.
  • HDMI Version1.3
  • Wire Gauge28 AWG
  • Jacket ColorBlack
  • Special FeaturesCL2 Rated,Flat
  • BrandDayton Audio
  • ModelHF13C210
  • Part Number181-796
  • UPC844632071072
  • Product CategoryHDMI Cables
    (7 Reviews)
  • Weight1.5000 lbs.
View similar products to the Dayton Audio HF13C210 33 ft. High-Speed Flat HDMI Cable
in the HDMI Cables product category.
Dayton Audio HF13C210 33 ft. High-Speed Flat HDMI Cable is rated 4.4286 out of 5 by 7.
Rated 5 out of 5 by from Great product great imageGot this cable for my home theater and it is perfect to hide it in tight spaces along the baseboard
Date published: 2014-07-10
Rated 5 out of 5 by from as advertisedworked fine right out of the wrapper, good connectors,good contact
Date published: 2014-03-05
Rated 1 out of 5 by from Very bad experience with this cable turns costlyBefore drilling holes in my walls and mounting wall plates from one room to the next, I decided I had better try this cable out. So I plugged one end into my very expensive and relatively new Marantz AV7005. I then ran the cable around the corner, down the hall and into my bedroom to the Panasonic 42" plasma on the wall. When I went to plug the cable into my TV, it sparked and ended up blowing all the HDMI inputs - taking out the control board and HDMI processor. Repairs? $360! (Too much to warrant, since I only paid $600 for the TV). If that wasn't bad enough, it also took out the three HDMI outputs on the AV7005 pre-amp! Fortunately, that was still under warranty. Would I recommend this to anyone? Duh, NO!When the TV repair place asked me if I tried the cable in anything else - I said "NO WAY! I can't afford to burn up any more equipment!"
Date published: 2011-12-01
Rated 5 out of 5 by from Dayton Audio HF13C210 33 ft. High-Speed Flat HDMI CablePerformance as advertised - great cable at a great price - link HD Laptop to HD TV for home entertainment center.
Date published: 2011-10-23
Rated 5 out of 5 by from Solid ProductWe use these cables daily. Excellent value and the flexibility of the flat profile make them the best value in HDMI in the marketplace. 10.2 Gbps in a 10 Meter HDMI cable at this price is huge.
Date published: 2009-10-24
Rated 5 out of 5 by from Perfect HDMI CableI purchased this cable because i can not run the video cable through the ceiling and had to run it under the carpet. The cable is flat enough to where you don't even feel it under the carpet and the picture quality is AMAZING! I am using it to connect my Xbox 360 to a Epson 720p projector and it was the perfect choice to complete my Home Theater.
Date published: 2009-02-14
Customer projects that include: Dayton Audio HF13C210 33 ft. High-Speed Flat HDMI Cable
