Dayton Audio HF13C21 3.3 ft. High-Speed Flat HDMI Cable
Brand:| Model: HF13C21
Dayton Audio's flat, high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. The flat design reduces the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b.
Which length will work best for you?
1.65 ft. Dayton Audio High-Speed Flat HDMI Cable3.3 ft. Dayton Audio High-Speed Flat HDMI Cable6.6 ft. Dayton Audio High-Speed Flat HDMI Cable9.9 ft. Dayton Audio High-Speed Flat HDMI Cable16.5 ft. Dayton Audio High-Speed Flat HDMI Cable23.1 ft. Dayton Audio High-Speed Flat HDMI Cable33 ft. Dayton Audio High-Speed Flat HDMI Cable
  • Supports resolutions up to 1600p, refresh rates up to 240 Hz, and 48-bit Deep Color
  • Flat cable construction reduces cable footprint while reducing cross-talk
  • HDCP compliant for protected content playback such as Blu-ray
  • ATC certified HDMI v1.3b Category 2
181-786
Weight: 0.2 lbs.
IN STOCK
List Price$15.99
You Save67%
$5.20
Buy 4-up$4.94
Part # 181-786
Dayton Audio's high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. Unleash the full potential of high definition 1080p video and lossless Dolby® TrueHD or DTS-HD Master Audio™ formats. Shielded, 28AWG twisted-pair oxygen-free conductors make this cable ideal for permanent installations. All connector contact surfaces are plated with 24 karat gold to provide a lifetime of reliable service. The flat design of these HDMI cables further separates the cable pairs reducing the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b compliance, as well as faster 340 MHz (10.2 Gbps) performance. Support for 240 Hz refresh rates, Lip Sync audio/video synchronization and future-proofing for monitors able to display up to a 1600p resolution is built-in.
No Questions Asked Lifetime Warranty
  • Cable TypeHDMI Male to Male
  • Cable Length3.3 ft.
  • HDMI Version1.3
  • Wire Gauge28 AWG
  • Jacket ColorBlack
  • Special FeaturesCL2 Rated,Flat
  • BrandDayton Audio
  • ModelHF13C21
  • Part Number181-786
  • UPC844632071027
  • Product CategoryHDMI Cables
    (9 Reviews)
  • Weight0.2 lbs.
View similar products to the Dayton Audio HF13C21 3.3 ft. High-Speed Flat HDMI Cable
in the HDMI Cables product category.
Dayton Audio HF13C21 3.3 ft. High-Speed Flat HDMI Cable is rated 5.0 out of 5 by 9.
Rated 5 out of 5 by from hdmithe hdmi cable dayton audio hf13c3.3 hi speed work just fine
Date published: 2014-08-03
Rated 5 out of 5 by from As AdvertizedDelivered and performs as advertised. Excellent value!
Date published: 2012-01-09
Rated 5 out of 5 by from HDMI cableAgain one could use a cable costing $$'s more and not see a difference. By instrumentation maybe/possibly. Use a 1.4 version cable though if you want 3D.
Date published: 2011-09-16
Rated 5 out of 5 by from carpenter's dreamMy particular installation required the flat panel lcd tv be installed close to the wall. This cable allowed a tight bend radius.
Date published: 2011-04-19
Rated 5 out of 5 by from HDMI ReadyHDMI cables are just what they are, cable to improve on the picture quality of an HD TV. It eliminates having to use extra wires or cables including component cables. Very clear picture with little or no adjustment. Very cost effective.
Date published: 2009-11-14
Rated 5 out of 5 by from Great cable, great valueYou don't need monster priced cable to get High Def from your flat panel. These cables work just as well at a fraction of the price.
Date published: 2009-11-01
Customer projects that include: Dayton Audio HF13C21 3.3 ft. High-Speed Flat HDMI Cable
