SALE
Dayton Audio H08RW 8" Round Waveguide 1-3/8"-18 TPI
Brand:|Model: H08RW|Part # 270-308
The Dayton Audio H08RW high frequency waveguide is precision molded from high-performance plastic, and has an industry-standard 1-3/8" x 18 TPI throat for mounting screw-on style drivers.
List Price$12.99
Regular Price$9.68
You Save23%
Sale Price
$7.50
Buy 20+$6.90
Part # 270-308
  • Uncolored, natural sound
  • Precision molded from high-performance plastic
  • Standard 1-3/8" x 18 TPI mounting for screw-on drivers
  • Nominal dispersion pattern: 75° conical
  • Recommended minimum crossover frequency of 2,200 Hz
A waveguide couples the high frequency driver to the listening space without the harmful distortion artifacts of marginally designed and implemented horn loading. It achieves this through the use of non-traditional geometries and lower expansion rates. The resultant sound has less distortion, with an "open" characteristic not often associated with typical "pinched" or "honky" compression driver/horn combinations. Dayton Audio waveguides reveal all of the articulate, accurate sound reproduction that your HF drivers are capable of delivering, whether the application is live sound, critical studio monitoring, or demanding home audio playback. The Dayton Audio H08RW high frequency waveguide is precision molded from high-performance plastic, and has an industry-standard 1-3/8" x 18 TPI throat for mounting screw-on style drivers. It is designed to exhibit a nominal 75° conical-shaped coverage pattern, and will provide useful acoustical loading down to 2,200 Hz. Dimensions: 8" round x 4-3/4" deep.
  • Mounting Type1-3/8"-18 TPI
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandDayton Audio
  • ModelH08RW
  • Part Number270-308
  • UPC844632009211
  • Product CategoryHorns & Waveguides
    (3 Reviews)
  • Weight0.6401 lbs.
View similar products to the Dayton Audio H08RW 8" Round Waveguide 1-3/8"-18 TPI
in the Horns & Waveguides product category.
