Dayton Audio DVC385-88 15" DVC Series Subwoofer
Brand:|Model: DVC385-88|Part # 295-190
The versatile Dayton Audio DVC385-88 15" DVC subwoofer is suitable for sealed, vented, bandpass, or even transmission line designs. The dual 8 ohm voice coils allow for use in a variety of home or auto applications.
Comparable Items In Stock:
Part # 295-190
  • Designed for sealed, vented, bandpass, and transmission line speaker systems
  • Dual 8 ohm voice coils offer plenty of connection flexibility
  • Kevlar-impregnated paper cone terminated with a durable, thick foam surround
  • US-engineered and manufactured 15" subwoofer driver
These DVC subwoofers are the most versatile drivers in the Dayton Audio line up. They were engineered to provide very good performance in sealed, vented, bandpass or even transmission line designs. The dual 8 ohm voice coils allow for use in a variety of applications and wiring configurations.
Each driver features a heavy gauge stamped steel frame, super stiff Kevlar impregnated paper cone, thick foam surround, flat progressive spider, vented pole piece, dual high power Kapton voice coils, and heavy duty braided tinsel leads. Made in the U.S.A. 5 Year Limited Warranty.
A knock-down 3.0 cubic foot subwoofer cabinet built specifically for the Dayton Audio DVC385-88 15" subwoofer is available here. Save 50% off the price of the cabinet when you buy the cabinet and DVC subwoofer (at regular price) together in this package only.
  • Nominal Diameter15"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response20 to 450 Hz
  • Sensitivity93.7 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Magnet Weight112 oz.
  • Resonant Frequency (Fs)20.9 Hz
  • DC Resistance (Re)2.4 ohms
  • Voice Coil Inductance (Le)2.31 mH
  • Mechanical Q (Qms)8.65
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)8.36 ft.³
  • Mechanical Compliance of Suspension (Cms)0.25 mm/N
  • BL Product (BL)12.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)234g
  • Maximum Linear Excursion (Xmax)15.1 mm
  • Surface Area of Cone (Sd)829.6 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialFoam
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.16"
  • Baffle Cutout Diameter13.77"
  • Depth6.57"
  • # Mounting Holes8
  • Sealed Volume2.05 ft.³
  • Sealed F342 Hz
  • Vented Volume4.74 ft.³
  • Vented F324 Hz
  • BrandDayton Audio
  • ModelDVC385-88
  • Part Number295-190
  • UPC844632000072
    (37 Reviews)
  • Weight19.4 lbs.
View similar products to the Dayton Audio DVC385-88 15" DVC Series Subwoofer
