300-384_ALT_0
300-384_ALT_1
300-384_ALT_2
300-384_ALT_3
Dayton Audio DTA-1AR Wireless Class T Digital Mini Amplifier/Receiver 15 WPC
Brand:| Model: DTA-1AR
Product Video
The DTA-1AR amplifier, part of the DTA-1W wireless mini amplifier system, is also a stand-alone amp. The DTA-1AR features an amplifier efficiency of up to 88% for long life when powered off batteries (8 AA batteries, not included) and cool operation. Its compact size is at home on any desk.
  • Amplifier efficiency of up to 88%
  • Compact sized amplifier/ receiver
  • Up to 20 meter (66 ft.) wireless range when used with the Dayton Audio DTA-1W (sold separately)
  • 3.5 mm local input for smartphone or MP3 connectivity
  • Battery powered for portable use
300-384
Weight: 1.05 lbs.
IN STOCK
List Price$69.99
You Save35%
$45.00
Part # 300-384
Dayton Audio cuts the cord holding your stereo system back with the DTA-1AR wireless mini amplifier receiver. When used wirelessly with the DTA-1T transmitter (included with the Dayton Audio DTA-1W; sold separately), true stereo sound is sent to the DTA-1AR amplifier/receiver via a 2.4 GHz signal while maintaining 20-20,000 Hz (-3 dB) frequency response. Up to 16 additional DTA-1ARs can be used with a single DTA-1T for increasing the size of your wireless system.
Built upon the tried-and-true Class T amplifier design, this system exhibits the same high-fidelity audio quality that audiophiles have come to love while remaining compact. The DTA-1AR is also a stand alone amplifier with local 3.5 mm input and is able to run off eight AA batteries (not included) or the included power supply. Rear mounted spring-loaded terminals make speaker connection quick and easy.
Includes a 6 in. 3.5 mm coiled male-to-male cable for making connections to iPods, MP3 players, PCs, portable CD or DVD players, and smartphones. Power supply included.
Specifications: • Power Output: 15 watts RMS x 2 (into 4 ohms) • Dynamic range: 90 dB • Sample rate: 44.1 kHz, 16-bit • Wireless Range: Up to 20 meters (66 ft.) line-of sight • Dimensions: 2" H x 6-1/8" W x 3-3/4" D.
  • Power Output (RMS Per Channel @ 8 ohms)10 Watts
  • Special FeaturesClass T,Wireless
  • BrandDayton Audio
  • ModelDTA-1AR
  • Part Number300-384
  • UPC844632094170
  • Product CategoryHome Audio Amplifiers
  • Weight1.05 lbs.
View similar products to the Dayton Audio DTA-1AR Wireless Class T Digital Mini Amplifier/Receiver 15 WPC
in the Home Audio Amplifiers product category.
Dayton Audio DTA-1AR Wireless Class T Digital Mini Amplifier/Receiver 15 WPC is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Pocket Rocket!I put in the required 8- AA batteries, hooked up a pair of 22 year old Realistic Nova-16's and my ipod... Couldn't believe the soundstage and clarity I was hearing! Best 50 bucks I've spent in a long time. This little amp blew away my expectations. Bravo!
Date published: 2011-11-08
Can I bridge the left and right outputs and use one amp per speaker (8ohm)?
Asked by: tofunater
This amplifier cannot be bridged, and none of the leads can be connected to each other.
Answered by: edegaston
Date published: 2012-05-21
Can the output be used to connect to headphones? (Can the "negative" speaker outputs be commoned?)
Asked by: nedw
NO. These are cheap 1-chip amplifiers with discrete floating outputs. Would be nice, though-it would require a buffer-amp and headphone connector.I haven't tried this one thing, may work: try connecting headphones using L & R and just one common connection....
Answered by: Fanden
Date published: 2012-02-22
Videos
Customer projects that include: Dayton Audio DTA-1AR Wireless Class T Digital Mini Amplifier/Receiver 15 WPC
