300-380_ALT_0
300-380_ALT_1
300-380_ALT_2
300-380_ALT_3
Dayton Audio DTA-1 Class T Digital AC/DC Battery Powered Mini Amplifier 15 WPC
Brand:| Model: DTA-1
Product Video
Dayton Audio's DTA-1 mini amplifier has the heart of a serious performer, in a truly portable package. The DTA-1's Class-T output chip produces imaging, dynamics, and sound quality that rival esoteric tube amps—up to 15 watts per channel is on tap to push compact speakers.
  • Palm-size Class-T 30 watt amplifier
  • Great sounding amp—also convenient for travel
  • Battery or AC powered—power supply included—for perfect portability
  • 88% amplifier efficiency prolongs battery life
  • Superior, hi-fi sound quality
  • Soft turn-on eliminates annoying speaker pop
  • CE and RoHS rated design
300-380
Weight: 1.1 lbs.
IN STOCK
List Price$59.99
You Save50%
$29.80
Buy 6-up$24.70
Part # 300-380
Don't let the compact size fool you—Dayton Audio's DTA-1 mini amplifier is a serious piece of audio gear. A proprietary Class-T amplifier chip enables the DTA-1 to be 88% efficient while still producing pristine, high-resolution output. This makes the DTA-1 T-Amp an obvious choice for powering high efficiency single driver speakers. Up to 15 watts of power per channel is on tap to drive desktop and bookshelf speakers, for the ultimate portable hi-fi setup at home or in your office.
The Dayton Audio DTA-1 T-Amp can run off of 8 AA batteries for total portability, or the included switching power supply (with quick-release US and European style plugs) for stationary use. A rear mounted 3.5 mm stereo (1/8") audio input is provided. The amplifier also includes a 6" long, coiled male-to-male 3.5 mm cable for making connections to iPods, MP3 players, PCs, and portable CD or DVD players. Spring-loaded push terminals are incorporated for quick speaker wire termination. Intelligent short-circuit and over-temperature protection ensure amplifier longevity. The Dayton Audio DTA-1 is the perfect replacement for the now unavailable Sonic Impact 5066 NIB class T amplifier. Dayton Audio has taken the technology developed for the Sonic Impact 5066 and perfected it in this hand-held digital amplifier.
Specifications: • Power output: 2 x 15 watts RMS (into 4 ohms @ 10% THD), 2 x 10 watts RMS (into 4 ohms @ 0.1% THD) • Efficiency: Greater than 88% • Dynamic range: 102 dB • Dimensions: 2" H x 6-1/8" W x 3-3/4" D
  • Special FeaturesClass T,Battery Operated
  • BrandDayton Audio
  • ModelDTA-1
  • Part Number300-380
  • UPC844632074356
  • Product CategoryHome Audio Amplifiers
    (109 Reviews)
  • Weight1.1 lbs.
  • Case Qty24
View similar products to the Dayton Audio DTA-1 Class T Digital AC/DC Battery Powered Mini Amplifier 15 WPC
in the Home Audio Amplifiers product category.
Dayton Audio DTA-1 Class T Digital AC/DC Mini Amplifier 15 WPC is rated 4.2569 out of 5 by 109.
Rated 5 out of 5 by from Clean lines and solid feelI bought this to power a couple of project speakers. I usually buy it naked and do my own thing but this time I wanted one that I could switch speakers occasionally. My favorite feature has to be the switching power supply. As long as the cord is pluged in it will not allow the battery juice to be used. As soon as the cord is removed the batteries kick in. Easy, ergonomic volume control that even my daughter with cerebral palsy is easily capable of using. Nice solid weight doesn't feel like it will slide all over the place. Like some of the other brands. Well done Dayton.
Date published: 2014-11-12
Rated 5 out of 5 by from minimalist excellenceI bought this for my computer after reading reviews online. I am really happy with it and consider myself to be a bit of an audiophile. Turning it up on max is distortion free. Sound is crystal clear. It is ideally suited for a computer or mp3 player. I must say I really love it and I am not easy to please! The only downside is a hum if disconnected from an input device but why would you have the thing on if it is not connected to music?
Date published: 2014-09-16
Rated 5 out of 5 by from Dayton Audio DTA-1I bought two Dayton Audio DTA-1s one for to power my wife"s computer speakers. The other I bought for myself out of curiosity. The amp in our TV room went down so I plugged in the Dayton Audio DTA-1 in its place. I'm running the little amp in a 2.1 configuration through a M&K Sub and a pair of Speakerlab Point Ones (0.1) 11"H x 7"W x 7"D and I don't know if I should be amused or impressed, actually both. The stereo separation is good and the over all sound quality excellent. Though the sound is not quite up to the NAD amp that the DTA-1 is replacing, it's far better than a sharp stick in the eye.I have not used the DTA-1 with batteries mainly because I'm to cheap to buy them. At about $30 THE dta-1 is a bargain, I would recommend this product. In my humbleopinion I think everyone should buy one if only to wow your audiophile friends.
Date published: 2014-09-06
Rated 4 out of 5 by from Almost 5 starsI bought this little amp after seeing a friends and I was very impressed with the sound and battery life. When I received mine there was an issue with the power supply being a loose fit, but I had a power supply from an old set of PC speakers that worked fine.This amp is very good for the price, especially paired with the Dayton bookshelf speakers. The amp survived many camping trips, backyard parties, and park outings before it let the smoke out at a tailgating party. Until it died after about 2 years of use/abuse it got lots of compliments. I had a pro audio guy at a birthday party ( he does line arrays for churches and stadiums) completely blown away by the sound this thing put out and he started lamenting about the old days of stereo racks and such.Battery life is VERY GOODSound is very good and will drive Dayton B652 speakers pretty well, don't expect lots of bass, but they do sound nice and carry more than enough sound for cocktail type gatherings.I will definitely buy another one.
Date published: 2014-08-04
Rated 2 out of 5 by from Sounds Good.... but....We bought this about a year ago. The amp sounds really great.. but one side quit working after 3 or 4 months.
Date published: 2014-02-17
Rated 5 out of 5 by from Good things come in small packages!I bought this amp almost 2 years ago and has provided some serious bang for your buck! After going through countless cheap, horrible sounding, clunky stereo cd receivers working in our Chick-fil-a's kitchen I decided to wire up some decent speakers and tuck away this amp, its so compact the whole system stayed out of the way of everything and sounded pretty good, considering the speaker placement and acoustics of the kitchen. I was worried it might not have enough power to really be heard in a loud kitchen but buy was I wrong! this little amp has plenty of power, without a lot of distortion at that. This little guy got us in trouble plenty of times because it could be easily heard through the whole store at only half volume.Fast forward year later I left Chick-fil-a and the amp got little to no use after I left so I switched it out for a clunky junker and after a deep cleaning shes running desk duty with 2 great infinity speakers and sounds better than any other receiver I own. So far she hasn't died, and hasn't been able to be replaced.
Date published: 2014-02-11
Can this amp be used in a monophonic configuration? Thanks in advance!
Asked by: Square Shiny
This amp cannot be bridged.
Date published: 2014-10-20
How much does it cost to ship the Dayton Audio DTA-1 to Israel?
Asked by: yuvalsarig
Please contact our sales and customer service for available stock, price and shipping options. sales@parts-express.com or 800-338-0531 x2.
Date published: 2014-10-14
I currently have this hooked up to 2 Pioneer SP-BS22-LR book shelf speakers 6 ohms. I was considering getting a powered sub and the one I am looking at has speaker level inputs and outputs. If I was to buy that would I still use this amp for my speakers?
Asked by: Berg
You could use The DTA-1 amp for the satellites or use the High Pass filter through the sub amp to power the external speakers. Both methods will work.
Answered by: TomI
Date published: 2014-09-30
If I hooked up 2 8 ohm speakers to this amp would it work.
Asked by: DJcrusher
Yes this amp will drive two 8 ohm speakers without a problem.
Date published: 2014-08-25
Will this amp drive a pair of JBL Control 1 Speakers well?
Asked by: Oxxy
Yes this will work well with a pair of Control 1 speakers.
Date published: 2014-08-11
Looking for a test amplifier for the CBT36 build. Would this amplifier be acceptable to use for this purpose. I didn't want to pay the bucks for the recommended test amplifier (DTA-100a), since I would have little use for it after completing the project.
Asked by: TomE
I don't see why this would not work for testing purposes in place of the dta 100. It should work fine in that application.
Answered by: Chrisf
Date published: 2014-07-18
Videos
Customer projects that include: Dayton Audio DTA-1 Class T Digital AC/DC Battery Powered Mini Amplifier 15 WPC
