Dayton Audio DSS4-SN Satin Nickel Speaker Spike Set 4 Pcs.
Brand:|Model: DSS4-SN|Part # 240-719
By rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system, it is possible to dramatically improve clarity, stereo imaging, and bass response.
List Price$38.99
Regular Price$29.70
You Save18%
Sale Price
$24.50
Part # 240-719
  • Dramatically improves clarity, stereo imaging, and bass response
  • Great results when used with subwoofer systems
  • Solid brass construction with attractive plated finish
  • Two-piece tip design for level adjustment
  • Barbed inserts can be mounted from inside or outside the cabinet
By rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system, it is possible to dramatically improve clarity, stereo imaging, and bass response. This is especially apparent with subwoofer systems. The Dayton Audio DSS Series spikes are precision machined from solid brass and then plated with a satin nickel finish. Each cone spike weighs 86 grams and measures 1-1/4" diameter and 1-1/2" tall. The two-piece threaded tip design allows for precise level adjustment. Barbed insert nuts and threaded studs are included for mounting internally or externally in cabinets with walls up to 1" thick. Set includes four satin nickel cone spikes, four satin nickel floor discs, four barbed inserts, and four M6 threaded studs.
  • Construction MaterialBrass
  • Color / FinishSatin Nickel
  • BrandDayton Audio
  • ModelDSS4-SN
  • Part Number240-719
  • UPC844632082399
  • Product CategorySpeaker Cabinet Spikes
    (3 Reviews)
  • Weight1 lbs.
View similar products to the Dayton Audio DSS4-SN Satin Nickel Speaker Spike Set 4 Pcs.
in the Speaker Cabinet Spikes product category.
