Dayton Audio DS90-8 3" Designer Series Extended-Range Speaker
Brand:|Model: DS90-8|Part # 295-422
The Dayton Audio Designer Series DS90-8 3" driver adds extended high frequency response to its outstanding mini-woofer performance.
List Price$21.99
Regular Price$16.37
You Save11%
Sale Price
$14.50
Part # 295-422
  • Cosmetic frame with low profile lip, designed for front mounting—no countersinking required!
  • Coated paper cone, half roll rubber surround for durability and accurate reproduction
  • Optimized to yield a low 3 dB down point and high potential output in a reasonably sized cabinet
  • Smooth frequency response and linear roll-off simplify filter design, guaranteeing good results with off-the-shelf crossovers
  • Vented pole piece for minimized power compression and maximized reliability
  • Generous Xmax capability encourages use of moderate bass boost to tailor the response
  • Retains the same "family look" as the popular Dayton Audio DVC Series subwoofers and passive radiators
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies—without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
• Suggested enclosures:
Sealed cabinet: Type: Acoustic suspension (alpha 3.5), Qtc 0.69; Size (internal) including volume displaced by driver: 0.03 ft³; Internal cabinet dimensions (golden ratio): 6-1/4"H x 3-7/8"W x 2-3/8"DTypical results: 3 dB down-point (f3): 158 Hz; Low frequency limit at rated power without exceeding conventional Xmax (i.e. (voice coil length – gap height) / 2)): 90 Hz.
Vented cabinet: Type: Bass reflex; Size (internal) including volume displaced by driver and port: 0.12 ft³; Internal cabinet dimensions (golden ratio): 7-3/4"H x 4-3/4"W x 3"D; Port dimensions (with flared exit): 1" dia. x 6"L. Typical results: 3 dB down-point (f3): 73 Hz; Tuning frequency (fb): 69 Hz; Low frequency limit at rated power without exceeding conventional Xmax (i.e. (voice coil length – gap height) / 2)): 70 Hz.
Frequency response (FRD) and Impedance (ZMA) data files available to assist in crossover and enclosure modeling.
  • Nominal Diameter3"
  • Power Handling (RMS)20 Watts
  • Power Handling (max)40 Watts
  • Impedance8 ohms
  • Frequency Response80 to 13,000 Hz
  • Sensitivity84.1 dB 2.83V/1m
  • Voice Coil Diameter0.8"
  • Magnet Weight8 oz.
  • Resonant Frequency (Fs)81.4 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.56 mH
  • Mechanical Q (Qms)2.19
  • Electromagnetic Q (Qes)0.53
  • Total Q (Qts)0.43
  • Compliance Equivalent Volume (Vas)0.05 ft.³
  • Mechanical Compliance of Suspension (Cms)1.02 mm/N
  • BL Product (BL)4.76 Tm
  • Diaphragm Mass Inc. Airload (Mms)3.8g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)31.2 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.63"
  • Baffle Cutout Diameter2.76"
  • Depth1.76"
  • Bolt Circle Diameter3.27"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3148 Hz
  • Vented Volume0.05 ft.³
  • Vented F380 Hz
  • BrandDayton Audio
  • ModelDS90-8
  • Part Number295-422
  • UPC844632095375
  • Product CategoryWoofers
    (2 Reviews)
  • Weight1.2 lbs.
View similar products to the Dayton Audio DS90-8 3" Designer Series Extended-Range Speaker
Videos
