Dayton Audio DS315-8 12" Designer Series Woofer Speaker
Brand:|Model: DS315-8|Part # 295-434
Great looks, high efficiency, and clean bass are notable attributes of Dayton Audio's Designer Series DS315-8 12" woofer.
List Price$98.99
You Save23%
Buy 4+$71.99
Part # 295-434
  • Cosmetic frame with low profile lip, designed for front mounting—no countersinking required!
  • Coated paper cone, half roll rubber surround for durability and accurate reproduction
  • Optimized to yield a low 3 dB down point and high potential output in a reasonably sized cabinet
  • Smooth frequency response and linear roll-off simplify filter design, guaranteeing good results with off-the-shelf crossovers
  • Vented pole piece for minimized power compression and maximized reliability
  • Generous Xmax capability encourages use of moderate bass boost to tailor the response
  • Retains the same "family look" as the popular Dayton Audio DVC Series subwoofers and passive radiators
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies—without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
  • Nominal Diameter12"
  • Power Handling (RMS)120 Watts
  • Power Handling (max)240 Watts
  • Impedance8 ohms
  • Frequency Response25 to 2,500 Hz
  • Sensitivity91 dB 2.83V/1m
  • Voice Coil Diameter1.95"
  • Magnet Weight77 oz.
  • Resonant Frequency (Fs)24.2 Hz
  • DC Resistance (Re)6.1 ohms
  • Voice Coil Inductance (Le)1.43 mH
  • Mechanical Q (Qms)1.79
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)5.62 ft.³
  • Mechanical Compliance of Suspension (Cms)0.44 mm/N
  • BL Product (BL)15.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)97.4g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)506.7 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.36"
  • Baffle Cutout Diameter10.71"
  • Depth5.12"
  • Bolt Circle Diameter11.97"
  • # Mounting Holes5
  • Sealed Volume0.93 ft.³
  • Sealed F360 Hz
  • Vented Volume1.9 ft.³
  • Vented F337 Hz
  • BrandDayton Audio
  • ModelDS315-8
  • Part Number295-434
  • UPC844632095436
  • Product CategoryWoofers
    (14 Reviews)
  • Weight13.4 lbs.
View similar products to the Dayton Audio DS315-8 12" Designer Series Woofer Speaker
