Dayton Audio DS270-8 10" Designer Series Woofer Speaker
Brand:|Model: DS270-8|Part # 295-432
The Dayton Audio Designer Series DS270-8 10" can operate at its full rated power down to 27 Hz without exceeding Xmax!
List Price$77.99
You Save23%
Buy 4+$56.86
Part # 295-432
  • Cosmetic frame with low profile lip, designed for front mounting—no countersinking required!
  • Coated paper cone, half roll rubber surround for durability and accurate reproduction
  • Optimized to yield a low 3 dB down point and high potential output in a reasonably sized cabinet
  • Smooth frequency response and linear roll-off simplify filter design, guaranteeing good results with off-the-shelf crossovers
  • Vented pole piece for minimized power compression and maximized reliability
  • Generous Xmax capability encourages use of moderate bass boost to tailor the response
  • Retains the same "family look" as the popular Dayton Audio DVC Series subwoofers and passive radiators
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies—without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
  • Nominal Diameter10"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 3,000 Hz
  • Sensitivity90.7 dB 2.83V/1m
  • Voice Coil Diameter1.52"
  • Magnet Weight62 oz.
  • Resonant Frequency (Fs)31.6 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)1.25 mH
  • Mechanical Q (Qms)2.40
  • Electromagnetic Q (Qes)0.54
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)3.09 ft.³
  • Mechanical Compliance of Suspension (Cms)0.48 mm/N
  • BL Product (BL)10.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)56.4g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)353 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.63"
  • Baffle Cutout Diameter8.94"
  • Depth4.41"
  • Bolt Circle Diameter10.24"
  • # Mounting Holes5
  • Sealed Volume1.28 ft.³
  • Sealed F355 Hz
  • Vented Volume3.38 ft.³
  • Vented F328 Hz
  • BrandDayton Audio
  • ModelDS270-8
  • Part Number295-432
  • UPC844632095429
  • Product CategoryWoofers
    (6 Reviews)
  • Weight10.3 lbs.
View similar products to the Dayton Audio DS270-8 10" Designer Series Woofer Speaker
