Dayton Audio DS175-8 6-1/2" Designer Series Woofer Speaker
Brand:|Model: DS175-8|Part # 295-428
Although it's true that the Dayton Audio Designer Series DS175-8 is a nice looking and well thought-out 6-1/2" woofer, its ability to handle full rated power down to 40 Hz* without exceeding Xmax is very impressive!
Regular Price$35.60
Sale Price
$32.50
Part # 295-428
  • Cosmetic frame with low profile lip, designed for front mounting—no countersinking required!
  • Coated paper cone, half roll rubber surround for durability and accurate reproduction
  • Optimized to yield a low 3 dB down point and high potential output in a reasonably sized cabinet
  • Smooth frequency response and linear roll-off simplify filter design, guaranteeing good results with off-the-shelf crossovers
  • Vented pole piece for minimized power compression and maximized reliability
  • Generous Xmax capability encourages use of moderate bass boost to tailor the response
  • Retains the same "family look" as the popular Dayton Audio DVC Series subwoofers and passive radiators
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies—without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)70 Watts
  • Power Handling (max)140 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,500 Hz
  • Sensitivity87.7 dB 2.83V/1m
  • Voice Coil Diameter1.39"
  • Magnet Weight33 oz.
  • Resonant Frequency (Fs)37 Hz
  • DC Resistance (Re)5.7 ohms
  • Voice Coil Inductance (Le)1.06 mH
  • Mechanical Q (Qms)1.63
  • Electromagnetic Q (Qes)0.32
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)0.60 ft.³
  • Mechanical Compliance of Suspension (Cms)0.71 mm/N
  • BL Product (BL)10.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)26g
  • Maximum Linear Excursion (Xmax)5.25 mm
  • Surface Area of Cone (Sd)128.7 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.91"
  • Baffle Cutout Diameter5.67"
  • Depth3.17"
  • Bolt Circle Diameter6.54"
  • # Mounting Holes5
  • Sealed Volume0.1 ft.³
  • Sealed F3106 Hz
  • Vented Volume0.2 ft.³
  • Vented F367 Hz
  • BrandDayton Audio
  • ModelDS175-8
  • Part Number295-428
  • UPC844632095405
  • Product CategoryWoofers
    (8 Reviews)
  • Weight4.95 lbs.
View similar products to the Dayton Audio DS175-8 6-1/2" Designer Series Woofer Speaker
Videos
