Dayton Audio DNR-3.0 3 Ohm 10W Precision Audio Grade Resisto
Dayton Audio DNR-3.0 3 Ohm 10W Precision Audio Grade Resistor
Brand:|Model: DNR-3.0|Part # 004-3
Dayton Audio DNR Series "Audio Grade" resistors are used in Zobel networks and fixed L-Pad attenuator circuits for tweeters. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance.
List Price$1.99
You Save31%
$1.38
Buy 4-49 $1.09
Buy 50+$0.88
Part # 004-3
Dayton Audio DNR Series "Audio Grade" resistors are primarily used in Zobel networks and fixed L-Pad attenuator circuits. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance. With a precision 2% tolerance, gold-plated oxygen free copper leads, and low-inductive wire wound construction, this resistor is a must for your next speaker crossover project! Dimensions: 48 mm L x 10 mm W x 10 mm H. Sold individually.
  • Resistance3 ohms
  • CompositionLow-Inductive Wirewound
  • Power Rating10 Watt
  • Tolerance2%
  • BrandDayton Audio
  • ModelDNR-3.0
  • Part Number004-3
  • UPC844632015328
  • Product CategoryAudio Grade / Non-inductive Resistors
    (3 Reviews)
  • Weight0.01 lbs.
View similar products to the Dayton Audio DNR-3.0 3 Ohm 10W Precision Audio Grade Resistor
in the Audio Grade / Non-inductive Resistors product category.
Dayton Audio DNR-3.0 3 Ohm 10W Precision Audio Grade Resistor is rated 4.3333 out of 5 by 3.
Rated 4 out of 5 by from They Do What Is NeededNot quite as good as Mills, but still do a nice job in padding tweeters, building L-pads and EQ/Zobel networks! If you have budget constraints, these are the way to go. Be nice if the leads were a little longer...
Date published: 2011-06-19
Rated 4 out of 5 by from It ResistsProduct arrived as described and worked, measured to 3ohm on a cheapo multi-meter.It did seem wasteful that PE shipped this $1.25 item in a $3-4.00 giant envelope.
Date published: 2009-12-01
Rated 5 out of 5 by from uh, review a resistor?It's the right value. It works. It's not annoyingly inductive. It does what it's supposed to do.
Date published: 2009-11-24
  • 2016-05-04T06:59CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_004-3, PRD, sort_mostRecent
