Dayton Audio DNR-2.4 2.4 Ohm 10W Precision Audio Grade Resi
Dayton Audio DNR-2.4 2.4 Ohm 10W Precision Audio Grade Resistor
Brand:|Model: DNR-2.4|Part # 004-2.4
Dayton Audio DNR Series "Audio Grade" resistors are used in Zobel networks and fixed L-Pad attenuator circuits for tweeters. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance.
List Price$1.99
You Save31%
$1.38
Buy 4-49 $1.09
Buy 50+$0.88
Part # 004-2.4
Dayton Audio DNR Series "Audio Grade" resistors are primarily used in Zobel networks and fixed L-Pad attenuator circuits. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance. With a precision 2% tolerance, gold-plated oxygen free copper leads, and low-inductive wire wound construction, this resistor is a must for your next speaker crossover project! Dimensions: 48 mm L x 10 mm W x 10 mm H. Sold individually.
  • Resistance2.4 ohms
  • CompositionLow-Inductive Wirewound
  • Power Rating10 Watt
  • Tolerance2%
  • BrandDayton Audio
  • ModelDNR-2.4
  • Part Number004-2.4
  • UPC844632015304
  • Product CategoryAudio Grade / Non-inductive Resistors
  • Weight0.01 lbs.
View similar products to the Dayton Audio DNR-2.4 2.4 Ohm 10W Precision Audio Grade Resistor
in the Audio Grade / Non-inductive Resistors product category.
The crossover in the speaker I am working on has a 2.2 ohm resistor in it and (2) 4 mF caps. Is this 2.4 ohm resistor close enough as a replacement or should I just leave the 2.2 in there now? I have used these Precision resistors before and like them.
Asked by: Joe9898
There will be very little difference between a 2.2 and a 2.4 ohm resistor in terms of what you can hear. If the existing resistors are not burnt or damaged there isn't much of a reason to change them.
Date published: 2014-09-04
To follow the other question, will these 10 or 12 Watt resistors work for an L Pad on the Morel CAT 308 tweeter, assuming I might pump 100 watts out of the amps into a passive 2.1 system? I want to match the tweeter to the Morel CAW 638.
Asked by: Rick64D
The tweeter will never see more than 10-15% of the total input power in a system. A 10 watt resistor will be fine in this application.
Date published: 2014-07-09
Can someone explain the power rating? I'm having trouble understanding how it works for resistors.
Asked by: LPAudio
The power rating on resistors or voltage rating on capacitors and inductors simply means that component can only handle that much power before it starts to fail.
Date published: 2014-03-21
  • 2016-02-10T08:04CST
  • loc_en_US, sid_004-2.4, PRD, sort_recentQuestionsFirst
