Dayton Audio DMPC-4.7 4.7uF 250V Polypropylene Capacitor
Brand:|Model: DMPC-4.7|Part # 027-422
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
List Price$3.39
You Save18%
$2.79
Buy 10-99 $2.56
Buy 100+$2.05
Part # 027-422
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 21 mm x 32 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
Specifications: • Rated: 250 VDC • Tolerance: 5% • Value: 4.7 uF • Dimensions: 21 mm Dia. x 32 mm L.
  • Capacitance4.7 µF
  • Voltage Rating250V
  • Tolerance5%
  • BrandDayton Audio
  • ModelDMPC-4.7
  • Part Number027-422
  • UPC844632013775
  • Product CategoryMetalized Polypropylene Crossover Capacitors
    (11 Reviews)
  • Weight0.021 lbs.
View similar products to the Dayton Audio DMPC-4.7 4.7uF 250V Polypropylene Capacitor
in the Metalized Polypropylene Crossover Capacitors product category.
Dayton Audio DMPC-4.7 4.7uF 250V Polypropylene Capacitor is rated 4.6364 out of 5 by 11.
Rated 5 out of 5 by from Great for Minimus 7Just rebuilt 4 pair of Minimus 7s ranging from the 40-2030B and several vintages of the 40-2030C. These caps made a huge improvement in the top end with the stock Japanese and Malaysian SD-50 and SD-60 tweeters.The Dayton 027-422 has a 10 kHz DF of 0.004. The various electrolytics used in the stock Minimus 7s had DFs ranging from 0.071 to 0.281 depending on vintage and manufacturer the small 50V Nichicons used in the later Minimus 7s being the worst. I always wondered why the later Minimus 7s had the more brittle top end - the x-over caps kept shrinking in size and quality.Would I buy more of these? Yes, I forgot a pair and that's why I'm back writing this review.
Date published: 2015-04-19
Rated 5 out of 5 by from Wonderful Audiophile grade capI replaced the stock cap on a Realistic Minimus 7 speaker and the tweeter came alive. The leads are plenty long enough to reach and solder and the cap was easy to hot glued to the inside of the speaker.
Date published: 2015-03-06
Rated 5 out of 5 by from High end sound...but affordableDo not get lost in the world of exotic capacitors in the audio chain. Oil caps and other exotoc caps are distorted/rolled off and not what they claim. If you have standard speaker for under several grand a pair, they were likely made with 10% electrolytic caps. These are the weakest link... not the drivers. Electrolytic caps smear time transients and distort the signal no matter what drivers are used. These dayton caps act more like a straight wire. No electrolytic gel to degrade and smear. ANY speaker that had electrolytics will sound VASTLY better with these capacitors. I have used these now for many years, and found that more expensive caps do not make any worthy difference like these do coming from electrolytics. More extended, smoother highs, tighter bass and cleaner mids. One of the best, and least expensive upgrades to your loudspeakers.
Date published: 2014-05-10
Rated 5 out of 5 by from Tweeter Crossover ReplacementI used two of these as replacements for intermittent OEM non-polarized electrolytics on tweeters in some stereo speakers. These worked great. The price is competitive and delivery was quick.
Date published: 2012-06-29
Rated 4 out of 5 by from my 2 centsi just started building crossovers ; after doing some reading it looks like these are not polarized. that being said i used these on a low cost tweeter and a coil on a low cost mid range driver with a low cost 2ch amp. after completeing the project i would have to say it dosent sound as good as my 5000 dollar car audio system or my high end home system but these capacitors definitly are not the week point. i look forward to trying these on higher end applications. to sumerize these caps do well with the cheap stuff i bought and will probably serve nicer tweeters much better. ( tang tweeters used 264-841 amp used 310-300 )
Date published: 2011-10-02
Rated 4 out of 5 by from Dayton Poly Caps:Always a smart buy !Esp when ordering sale speakers & parts of questionable quality.Their good quality,consistant & no noticable sound signature,very impasive.
Date published: 2010-08-26
  • 2016-02-06T07:51CST
  • co_hasreviews, tv_0, tr_11
  • loc_en_US, sid_027-422, PRD, sort_mostRecent
Hi Can I replace my crossover 10MFD 50V Bi-polar for your Dayton Audio DMPC-10 10uF 250V Polypropylene Capacitor and for 4.2MFD 50V what do you recommend I only see in you web site 4.0uF and 4.7uF , please let me know Thank you
Asked by: Julian64
You can either use a 4.0 uF as a replacement and likely not hear a difference, or add a 0.2 uF in parallel with it to get the exact value you need.
Date published: 2014-03-13
  • 2016-02-06T08:36CST
  • loc_en_US, sid_027-422, PRD, sort_recentQuestionsFirst
