Dayton Audio DMPC-4.3 4.3uF 250V Polypropylene Capacitor
Brand:|Model: DMPC-4.3|Part # 027-419
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
List Price$3.39
You Save15%
$2.88
Buy 10-99 $2.58
Buy 100+$2.06
Part # 027-419
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Dimensions: 18 mm x 31 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
Specifications: • Rated: 250 VDC • Tolerance: 5% • Value: 4.3 uF • Dimensions: 18 mm Dia. x 31 mm L.
  • Capacitance4.3 µF
  • Voltage Rating250V
  • Tolerance5%
  • BrandDayton Audio
  • ModelDMPC-4.3
  • Part Number027-419
  • UPC844632014611
  • Product CategoryMetalized Polypropylene Crossover Capacitors
  • Weight0.005 lbs.
