Dayton Audio DMPC-3.3 3.3uF 250V Polypropylene Capacitor
Brand:|Model: DMPC-3.3|Part # 027-420
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
List Price$2.39
You Save17%
$1.98
Buy 10-99 $1.80
Buy 100+$1.44
Part # 027-420
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 17.5 mm x 31 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
Specifications: • Rated: 250 VDC • Tolerance: 5% • Value: 3.30 uF • Dimensions: 17.5 mm Dia. x 31 mm L.
  • Capacitance3.3 µF
  • Voltage Rating250V
  • Tolerance5%
  • BrandDayton Audio
  • ModelDMPC-3.3
  • Part Number027-420
  • UPC844632013768
  • Product CategoryMetalized Polypropylene Crossover Capacitors
    (12 Reviews)
  • Weight0.0155 lbs.
View similar products to the Dayton Audio DMPC-3.3 3.3uF 250V Polypropylene Capacitor
in the Metalized Polypropylene Crossover Capacitors product category.
Dayton Audio DMPC-3.3 3.3uF 250V Polypropylene Capacitor is rated 4.9167 out of 5 by 12.
Rated 5 out of 5 by from Crisp and Clear SoundI bought a pair of these caps to make sure that I don't go below the recommended frequency on a pair of replacement tweeters. Install was a snap, and they make the tweeters sound so pure. Good stuff.
Date published: 2015-10-21
Rated 5 out of 5 by from dayton polypropelene capsGood quality caps, for the price they are hard to beat. Did not notice any sonic variations from other more expensive " botique caps".
Date published: 2015-04-05
Rated 5 out of 5 by from Replacement for Infinity Reference 2I needed 3.5uf for Infinity Reference 2. 3.3uf Daytons were plenty close for the job. Dayton caps sound great at a great price!
Date published: 2014-11-17
Rated 5 out of 5 by from PRoduct consistency is ExcellentI only needed 6 of these but, I bought 10 so that I can pick the ones closest to the values that I needed from the lot. Using DATS, I measure these and they were all measure within 1% of each other. Very happy with these.
Date published: 2013-02-24
Rated 5 out of 5 by from Dayton CapJust soldered these in a few moments ago in series with my tweeters. Very much improvement was had over the stock electrolytics these now replace. Stereo imaging is much better with a bit of improvement in depth. Not to mention they are no longer harsh to my ears. A vast improvement over the electro's, and great detail, the speakers finally disappear in the room. These will surely not disappoint.
Date published: 2013-01-18
Rated 5 out of 5 by from Best cap for the price.This caps give you more than you spect for the price. Precise on the frequency cut, very good construction and very detail on the hi frequency. If you want something better you have to look on very expensive ones.
Date published: 2011-12-15
  • 2016-02-09T06:48CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_027-420, PRD, sort_mostRecent
are these non-polarized? or is there a way to use polarized caps in place of non-polarized/bi-polar caps in a crossover?
Asked by: kwape
Yes these are non polarized. You do not want to use a polarized cap for a crossover application.
Date published: 2015-03-02
What is the best size cap to use on a 10' mid range speaker
Asked by: Doobie
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-10-09
  • 2016-02-09T07:26CST
  • loc_en_US, sid_027-420, PRD, sort_recentQuestionsFirst
