Dayton Audio DMPC-1.5 1.5uF 250V Polypropylene Capacitor
Brand:|Model: DMPC-1.5|Part # 027-412
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
OUT OF STOCK
Due In: 1/31/2017
List Price$1.79
You Save20%
$1.44
Buy 10-99 $1.32
Buy 100+$1.06
Part # 027-412
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 11 mm x 31 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
Specifications: • Rated: 250 VDC • Tolerance: 5% • Value: 1.5 uF • Dimensions: 11 mm Dia. x 31 mm L.
  • Capacitance1.5 µF
  • Voltage Rating250V
  • Tolerance5%
  • BrandDayton Audio
  • ModelDMPC-1.5
  • Part Number027-412
  • UPC844632013720
  • Product CategoryMetalized Polypropylene Crossover Capacitors
    (4 Reviews)
  • Weight0.008 lbs.
View similar products to the Dayton Audio DMPC-1.5 1.5uF 250V Polypropylene Capacitor
in the Metalized Polypropylene Crossover Capacitors product category.
