Dayton Audio DMPC-100 100uF 250V Polypropylene Capacitor
Brand:|Model: DMPC-100|Part # 027-447
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
List Price$38.99
Regular Price$32.49
You Save20%
Sale Price
$25.99
Buy 100+$23.85
Part # 027-447
  • 250 VDC rating
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 51 mm x 77 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers. Large values are great for 3-way speaker designs.
Specifications: • Rated: 250 VDC • Tolerance: 5% • Value: 100.0 uF • Dimensions: 51 mm Dia. x 77 mm L.
  • Capacitance100 µF
  • Voltage Rating250V
  • Tolerance5%
  • BrandDayton Audio
  • ModelDMPC-100
  • Part Number027-447
  • UPC844632016356
  • Product CategoryMetalized Polypropylene Crossover Capacitors
    (7 Reviews)
  • Weight0.25 lbs.
View similar products to the Dayton Audio DMPC-100 100uF 250V Polypropylene Capacitor
in the Metalized Polypropylene Crossover Capacitors product category.
Dayton Audio DMPC-100 100uF 250V Polypropylene Capacitor is rated 4.5714 out of 5 by 7.
Rated 5 out of 5 by from Dayton Polypro CapsI bought five different size caps to recap my AR91 speakers. I chose the precision caps for the smaller values BUT there was no need as the 5% tolerance caps were all within 1%. I was amazed. My speakers sound great too.
Date published: 2014-11-22
Rated 4 out of 5 by from Great value productI use this Dayton line in all my classic Acoustic Research crossover rebuilds and have never been disappointed.
Date published: 2010-03-19
Rated 5 out of 5 by from Nice Capacitor!Bought 14 various values of the 5% metalized film caps offered from Parts Express to completely rebuild crossovers in KEF model 105's.They now sound MUCH BETTER! These are hi-quality! I gave them a 4.5 for performance, for if cost is no object in a project like this there is better for much more $$.This value is physically LARGE, so take that into consideration for fit!
Date published: 2010-01-31
Rated 4 out of 5 by from good capgood value
Date published: 2009-03-06
Rated 5 out of 5 by from worth to tryExcellent product, try it and buy it! Need break-in time.
Date published: 2009-02-22
Rated 5 out of 5 by from Great Large Film CapIt's pretty rare to see film caps approach values this high. These give very good performance, and they're 20% the cost of some other high end brands. I'm currently using 4 as coupling caps in a balanced headphone amp.-Paul
Date published: 2008-02-15
  • 2016-05-05T06:36CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_027-447, PRD, sort_mostRecent
can you combine film caps with electrolyic caps to reach required value?
due to lack of space I cannot use large film caps in combination to achieve a value of 500uf.Can I use a 400uf electrolytic and combine with a 100uf film cap? I would like to use this combination in a speaker crossover. Also will it provide better "sound" than with an electrolytic alone? Thanks
Asked by: Mike54
Electrolytics do not sound good. So combining them with poly is a great idea that saves money. Also in your case, using multiple caps will increase the current capacity making the crossover more stable - meaning it won't saturate as easily and will perform more linearly. First use high voltage caps. Try to have 50% be poly, but no less than around 25%.
Answered by: markajh
Date published: 2013-10-10
  • 2016-05-05T06:58CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • loc_en_US, sid_027-447, PRD, sort_recentQuestionsFirst
