Dayton Audio DMPC-1.0 1.0uF 250V Polypropylene Capacitor
Brand:|Model: DMPC-1.0|Part # 027-410
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
List Price$1.59
You Save22%
$1.24
Buy 10-99 $1.19
Buy 100+$0.95
Part # 027-410
  • 250 VDC
  • 10% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 10.5 mm x 31 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
Specifications: • Rated: 250 VDC • Tolerance: 5% • Value: 1.0 uF • Dimensions: 10.5 mm Dia. x 31 mm L.
  • Capacitance1.0 µF
  • Voltage Rating250V
  • Tolerance5%
  • BrandDayton Audio
  • ModelDMPC-1.0
  • Part Number027-410
  • UPC844632013713
  • Product CategoryMetalized Polypropylene Crossover Capacitors
    (2 Reviews)
  • Weight0.005 lbs.
View similar products to the Dayton Audio DMPC-1.0 1.0uF 250V Polypropylene Capacitor
in the Metalized Polypropylene Crossover Capacitors product category.
Dayton Audio DMPC-1.0 1.0uF 250V Polypropylene Capacitor is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from Great Value CapsI have used Dayton caps in amp and preamp, and they sound great in both. The quality is great and you can't get much better for the money.
Date published: 2009-03-19
Rated 4 out of 5 by from Great Budget HIFI CapacitorI used this as a bypass for the electrolytic HV filter cap on my tube amp and it performs great. I like the higher voltage rating and the cost is much lower than most caps at their quality point. I have used Dayton caps in the past and will use them again.
Date published: 2008-09-23
  • 2016-02-12T06:49CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_027-410, PRD, sort_mostRecent
