Dayton Audio DCS450-4 18" Classic Subwoofer 4 Ohm
Brand:|Model: DCS450-4|Part # 295-475
Choose the Dayton Audio DCS450-8 Classic Series 18" subwoofer for use as a high output, low frequency home theater subwoofer.
List Price$162.99
You Save23%
$125.25
Buy 4+$119.50
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
*Domestic US orders only
Part # 295-475
  • Heavy-duty treated paper cone for high stiffness-to-weight ratio
  • 3" aluminum former, 4-layer voice coil, and large vented pole piece for high power handling
  • Large diameter flat spider and healthy Xmax for clean bass
  • High sensitivity
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DCS450-8 18" subwoofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. Extended bass response and generous Xmax make this driver ideal for use in high output subwoofers. A Qts of 0.47 allows the DCS450-8 to work well in both sealed and ported speaker enclosures.
A polymer laminate paper cone offers rigidity, while the 3" four-layer high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
  • Nominal Diameter18"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)600 Watts
  • Impedance4 ohms
  • Frequency Response22 to 500 Hz
  • Sensitivity95.9 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)26.2 Hz
  • DC Resistance (Re)3 ohms
  • Voice Coil Inductance (Le)3.23 mH
  • Mechanical Q (Qms)4.98
  • Electromagnetic Q (Qes)0.48
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)8.76 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)16.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)273g
  • Maximum Linear Excursion (Xmax)8.25 mm
  • Surface Area of Cone (Sd)1134.1 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter17.87"
  • Baffle Cutout Diameter16.42"
  • Depth8.37"
  • Bolt Circle Diameter17.4"
  • # Mounting Holes8
  • Sealed Volume3.85 ft.³
  • Sealed F346 Hz
  • Vented Volume13.01 ft.³
  • Vented F325 Hz
  • BrandDayton Audio
  • ModelDCS450-4
  • Part Number295-475
  • UPC844632062315
  • Product CategoryWoofers
    (33 Reviews)
  • Weight24 lbs.
View similar products to the Dayton Audio DCS450-4 18" Classic Subwoofer 4 Ohm
