Dayton Audio DCS380-4 15" Classic Subwoofer 4 Ohm
Brand:|Model: DCS380-4|Part # 295-470
Excellent general-purpose subwoofer that works well in sealed or vented enclosures.
List Price$116.99
You Save23%
Buy 4+$86.93
Part # 295-470
  • Heavy-duty treated paper cone for high stiffness-to-weight ratio
  • 2" aluminum former, 4-layer voice coil, and large vented pole piece for high power handling
  • Large diameter flat spider and healthy Xmax for clean bass
The Dayton Audio Classic 15" Subwoofer is an excellent general-purpose subwoofer that works well as a replacement in powered subwoofer systems, or for new system design and construction. For the utmost versatility, the parameters are suitable for sealed or vented enclosures. The heavy-duty cone, wide-roll rubber surround, and long linear excursion ensure excellent low-bass performance.
  • Nominal Diameter15"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance4 ohms
  • Frequency Response20 to 500 Hz
  • Sensitivity93.6 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)21.5 Hz
  • DC Resistance (Re)2.9 ohms
  • Voice Coil Inductance (Le)2.31 mH
  • Mechanical Q (Qms)3.79
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)9.43 ft.³
  • Mechanical Compliance of Suspension (Cms)0.29 mm/N
  • BL Product (BL)12.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)190g
  • Maximum Linear Excursion (Xmax)8.4 mm
  • Surface Area of Cone (Sd)819.4 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.16"
  • Baffle Cutout Diameter13.74"
  • Depth7.32"
  • Bolt Circle Diameter14.37"
  • # Mounting Holes8
  • Sealed Volume3.84 ft.³
  • Sealed F340 Hz
  • Vented Volume12.77 ft.³
  • Vented F321 Hz
  • BrandDayton Audio
  • ModelDCS380-4
  • Part Number295-470
  • UPC844632009877
  • Product CategoryWoofers
    (31 Reviews)
  • Weight13.7401 lbs.
View similar products to the Dayton Audio DCS380-4 15" Classic Subwoofer 4 Ohm
