Dayton Audio DCS305-4 12" Classic Subwoofer 4 Ohm
Brand:|Model: DCS305-4|Part # 295-204
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses.
List Price$110.99
You Save23%
$85.00
Buy 4+$80.85
Part # 295-204
  • Sturdy stamped steel frame
  • Vented pole piece and bumped back plate
  • Inductance-reducing copper pole piece cap
  • Treated non-pressed paper/Kevlar cone with rubber surround
  • 4-layer VC with polyimide former
  • Great for home and automotive applications
  • Five year warranty
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses. The drivers feature a vented pole piece with copper cap, bumped back plate for improved excursion capability, Kevlar reinforced cone with rubber half-roll surround, and a high-temperature 4-layer copper voice coil wound on a polyimide former.
  • Nominal Diameter12"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance4 ohms
  • Frequency Response23 to 200 Hz
  • Sensitivity90.5 dB 2.83V/1m
  • Voice Coil Diameter2.57"
  • Resonant Frequency (Fs)24.2 Hz
  • DC Resistance (Re)3.3 ohms
  • Voice Coil Inductance (Le)2.06 mH
  • Mechanical Q (Qms)5.07
  • Electromagnetic Q (Qes)0.43
  • Total Q (Qts)0.40
  • Compliance Equivalent Volume (Vas)3.25 ft.³
  • Mechanical Compliance of Suspension (Cms)0.27 mm/N
  • BL Product (BL)13.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)160g
  • Maximum Linear Excursion (Xmax)9.3 mm
  • Surface Area of Cone (Sd)498.8 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.05"
  • Baffle Cutout Diameter10.83"
  • Depth6.02"
  • Bolt Circle Diameter11.59"
  • # Mounting Holes8
  • Sealed Volume1.14 ft.³
  • Sealed F348 Hz
  • Vented Volume3.42 ft.³
  • Vented F326 Hz
  • BrandDayton Audio
  • ModelDCS305-4
  • Part Number295-204
  • UPC844632080678
    (19 Reviews)
  • Weight13.3 lbs.
View similar products to the Dayton Audio DCS305-4 12" Classic Subwoofer 4 Ohm
Dayton Audio DCS305-4 12" Classic Subwoofer 4 Ohm is rated 4.7895 out of 5 by 19.
Rated 5 out of 5 by from Power House Is RightI'm using two of these, one in each enclosure with the Dayton 250 Watt plate amp and a Dayton 6.5 designer series mid base and Pyle horn loaded tweeter with a -7dB resister network attenuator.This woofer is in about 2.2 cubic foot volume sealed, packed with fiberglass. This set up really kicks with the subsonic frequencies that rattle the house.
Date published: 2015-11-23
Rated 5 out of 5 by from Nice SubInstalled this with a 250 Dayton Audio plate amp in a 3.2 cu ft ported box. Loving it so far.
Date published: 2015-09-13
Rated 5 out of 5 by from Great replacement wooferI picked up a pair of these to replace the 12 inchers in my 26 year old Klipsch Forte IIs (one of them blew after all that time). After researching for over a week I found myself back at parts express buying these. I couldn't be happier. They differed a little from stock in wattage and a few other specs, but they work well with the passive radiator. I may be hearing things but these sound tighter and slightly more dynamic than the originals.
Date published: 2015-03-12
Rated 5 out of 5 by from Great sound!The woofer in my 15 year old Kenwood powered subwoofer finally self destructed. Rather than spend the bucks on an entire new subwoofer, I decided to just replace the speaker. I ordered this speaker as a replacement and it's by far better than the original with a much bigger magnet and a crisper sound.The old Kenwood sounds better now than it did when new.Also, thanks to Parts Direct for their excellent service.
Date published: 2015-02-16
Rated 5 out of 5 by from Dayton Subwoofer...Great replacementI have an old KLH 200 watt subwoofer that I used in my tv audio chain. The original 12" speaker was cutting out and showing signs of deterioration. The Dayton appeared to be an upgrade and a well made replacement. Other than having to slightly enlarge the cabinet fitting, replacement was fairly straight forward. The result is a much tighter and cleaner sounding sub that blends perfectly w/ the system. And the price was great!
Date published: 2014-11-13
Rated 5 out of 5 by from Great speaker, just maybe not in 3-way towerI bought a pair of these as woofer replacements for my DCM KX-12 towers. I needed 4 ohm woofers, and these seemed to have the power handling I needed. I was wondering about the frequency response as a woofer, and unfortunately they didn't have enough range. However, as a subwoofer speaker, these Daytons are very well constructed, nice looking, beefy. I'd not hesitate to put them in an actual subwoofer box, or as a replacement if I needed strictly a sub. The excellent rating is for that part. These are worth the price, and in the towers, the bottom end was tremendous.
Date published: 2014-10-16
  • 2016-02-09T06:24CST
  • co_hasreviews, tv_0, tr_19
  • loc_en_US, sid_295-204, PRD, sort_mostRecent
Like Rusticman a year ago, I have a blown speaker in a Paradigm PDR-12.  The inside of the cabinet is 1.6 cu. ft., not 2.  And it has a big piece of cotton batting, 26x10x1.8 inches.  The current speaker is 4 ohms.  Does your answer change?
Asked by: sotall
The volume is a little on the small side but it will still work well. I would still recommend sealing up one port to help lower the tune a bit.
Date published: 2015-11-13
Hi PE, I'm currently busy with building a 2.1 Setup for my living room. I'm thinking about using this driver for my subwoofer, however, I prefer a sealed box but I want to tune it to about 30Hz. How big should my enclosure be? And how much filling?
Asked by: HouyuS
You cannot tune a sealed enclosure. The recommended sealed volume under the product details will provide in room response into the low 30's without a problem. We recommend a half pound of stuffing per cubic foot of volume.
Date published: 2016-01-09
Does this driver come with mounting screws? If yes what size? If no what size do I need? I would like to secure it with hurricane nuts, which ones should I use?
Asked by: ThisJustin
These do not include screws. If you are using hurricane nuts, a #10-32 would work with this driver.
Date published: 2015-08-31
What dimension box would I need for good extension into 20 or 30 Hz range. 2x12 sub with slot port(s). Height of the front mounting board is 17". Would be interested in dimension of a similar 1x12, which would also have a 17" front board.
Asked by: Ibjm
I would recommend an enclosure that measures 17"H x 32"W x 18"D externally with a single slot port that measures 2"W x 15.5"H and is 14"D. This will tune the enclosure to 32 Hz.
Date published: 2015-08-04
Trying to find box size for a 2x12 sub. Must use these drivers. Goal is pretty punchy bass, and hopefully hz in the 20's or 30's. Must keep box height close to the height of the drivers, so ports would ideally be slots on the ends. Thanks.
Asked by: Ibjm
A box that measures 13"H x 31"W x 18"D externally with a single slot port that measures 11.5"H x 2"W x 20"L will tune the box to 31 Hz and provide extension into the 20's.
Date published: 2015-07-02
Im planning to build a box with this driver and the SPA250 Dayton Audio plate amp and how do i tune the box using 2 ports (to match the rest of the system) for an F3 in the 30Hz zone??
Asked by: Speak Freak
I would recommend a 3.8 cubic foot enclosure with two 3" dual flared ports that are 17" long each for a tuning frequency of 24 Hz and an F3 of 24 Hz.
Date published: 2015-05-21
  • 2016-02-09T07:03CST
  • co_hasquestionsanswers, tq_24
  • loc_en_US, sid_295-204, PRD, sort_recentQuestionsFirst
